dart pro 1 turbo set up
Link to PRC heads:
https://ls1tech.com/forums/generation-iv-internal-engine/616405-precision-race-components-ported-6-2l-cylinder-heads-almost-ready.html
that being said, and now the same MASS of air gets into the cylinder at from 20psi as it would 15psi through big heads. now the valves are closed and then whats happens to make it more violent?
the 20psi engine will see more backpressure from the turbo(s), if you have a good exhaust and proper turbo set up the change would also be minimal increase. resulting in a minimal drop in efficiency.. easily overshadowed by a fraction of the boost you added.
mouse i can see your point, your saying as long as you cool down the intake charge leaving the turbo due to higher boost you can make the same amout of power with less exspencive heads right? Meaning bigger intercooler and other means. I was just thinking if i keep the boost down by running better heads i can cool the intake charge down even more with a bigger intercooler meaning when i do turn the boost up i will make even more hp. Like my lq9 heads i have right now i can get em ported and run some very good numbers but then theres the casting being thicker of a aftermarket head thats insurance you think? well let me check out the link for intakes this was very intersting indeed thanks guys , mouse ,john and alll
For 1000rwhp I would not play with any stock head castings.
Link to PRC heads:
https://ls1tech.com/forums/showthread.php?t=616405
enough time has not been put into testing those heads to try my luck with them i just read the whole thread and they havent proven them heads yet but they sound nice so far
what you say here means you now eventually want more than 1000, which is a change from your original post. this would get into the realm of a stronger head for sure... still not necessarily one that flows more.
Link to PRC heads:
That being said, I plan to run a ported set of these on a stock LS2 motor at about the 650-700rwhp level and see what happens. Would I try it at 1000? Nope.
I agree with John, I would rather go with an aftermarket head when trying to make 1000rwhp. I already had the ported stock castings when the motor was being built. In addition, the stockers on my motor have had the decks welded and a lot of strengthening done. When the motor goes for the solid roller conversion in a couple of months I am going to switch to a set of the All Pro W heads.
quick example: 3.0L supras make 1500rwhp with GT47 88mm turbo's
The same turbo on a big cubic inch LS1's aren't coming close to those power levels. They are stuck in the 1200rwhp range.
The 3.0L are seeing 60psi (boost) while the LS1's are only seeing 30psi (boost) before it runs out of air.
so i agree with mightymouse
just my .02
If your system has a flow problem that requires additional boost to overcome, then you build more heat in the intake and ex. The better intercooler could fix the intake, but how do we cool the ex? Maybe sacrifice power and run rich?
Kurt
just my .02
more exhaust heat = more spoolz yo!
I dont have a comeback for the exhaust heat other than keep an eye on your pressure ratio and egt and design a minimal backpressure system. I have melted a lot of parts
but i think we both agree they are from an octane defficiency. Look at it this way. A given turbo will make 1000hp at the crank. But that same turbo will work more efficiently with one engine vs. another... But also work differently with different size engines... But also work differently with different flowing heads... Will work differently with different cam shafts.
If you are specifically focused on making 1000rwhp with a single, with a 370ci engine, some turbo companies will immediately focus you on a 91/91.5 mm turbo. Some guys might try to put you in a 94mm but I bet the PTE guys would start with a 91mm turbo.
well john i feel you cause im planning on going with a pt 91.5 well im about to do a search on the intakes ls6 vs carb style lol. there was a lot of good imput on here. Great disscusion
https://ls1tech.com/forums/forced-induction/605899-reason-switching-carb-intake.html
https://ls1tech.com/forums/forced-induction/610806-what-intake-manifold.html
https://ls1tech.com/forums/forced-induction/608508-victor-jr-efi-intake-346-d1-worth.html
https://ls1tech.com/forums/forced-induction/596738-gmpp-intake.html
i dont understand how the 20psi combo sees more backpressure since it has to use more of the exhaust energy to spin the turbo........please someone try to explain this to me cause i dont understand that.
