Building a sequential turbo system
Old Mar 22, 2007 | 03:02 AM
  #81
chuntington101's Avatar
Speed, great work as ever mate! and my G*D your welding is good!
how do you manage to find the money, time and skills do do all this project??
thanks Chris.
Old Mar 23, 2007 | 11:33 AM
  #82
Speed's Avatar
Thanks for the kind word guys. Money and skills just come from that time . Tiago knows about my love for the TIG.
Anyway, made some more progress over the last couple days. I got the rest of the up-pipe built and turbos positioned and mounted. The up-pipe turned out to be a freaky little beast due to the routing and diverter valve positioning.
Couple pics of the primary turbo installed
Old Mar 24, 2007 | 01:33 AM
  #83
Speed's Avatar
Got the wastegate installed and the log is finally mounted. Man, these big pushes to get something finished can really take a toll on the ol body. I did have one glitch though. When I installed the log I couldn't get the middle two bolts through the gasket. Finally I pulled the log and seen that I had welded the flange on backwards. Oops. In worrying about all the details of the build I got the flange right side up but backwards reversing the middle two holes. No big deal, I just redrilled the flange and it worked fine. I could have kicked myself for missing that. I guess we've had the glitch for this mission....
Here are a couple pics of the log. This one shows the 02 sensor bung, and wastegate flange installed.
And finally buttoned up in the car. The wastegate is a 60mm TurboXS (ebay) unit. It caught my eye searching for blue wastegates. It looked neat and I was curious so I bought it. The quality seems to be good so I figured I would try it. With a 2.5in inlet and up to a 2.25in discharge, it should have no problem keeping the boost under control when I do decide to crank it up.
Also got the oil feed line installed and bracket made from some aluminum I had laying around to mount the scavenge pump but I don't have any pics of that. I'll post some up tomorrow. Hopefully I'll be able to pull the rest together tomorrow and start her up!
Old Mar 24, 2007 | 04:25 AM
  #84
looking good. any chance of a engine bay pic so we can see where everything is going????
thanks Chris.
Old Mar 24, 2007 | 01:18 PM
  #85
Tiago's Avatar
things are shaping up, awesome
Old Mar 26, 2007 | 09:05 AM
  #86
Speed's Avatar
thanks Chris.
Yeah, I'll snap a couple when I get the cold side done.
Slowly but surely. I'm fricken beat man. I feel like I just ran the Ironman....
While I didn't get the hot side finished as I had hoped this weekend, I'm damn close and everything is coming together pretty well. I alllllllllllmost got the crossover pipe buttoned up but a minor misalignment between pipes will require sneaking a probably 4* bend in place just to keep things flowing well. I could have cheater cut it but I have enough little chunks of bend laying around that I'm sure I have something that will work.
I will say dynomax bends suck these days. Some of them loose almost .25in in the diameter through the bend. I had a bunch of older bends that didn't seem to have this problem. This only really seems to be the case with the 16ga 2.5in bends. The 3in seemed fine.
I had a pic of the completed down pipe but it disappeared. It's a freaky little beast too. I'll get a pic up tomorrow. I am proud of this little setup. I figure if I ever get rid of the turbo system, I've got a way to plumb an apartment building.
Return to the oil fill cap. At some point (when building the next motor I'm sure), I'll plumb this into the pan or timing cover but for now I think this will work nice. When I do, I'll swap it over to the 14hp mobile 1 cap.
In this entire project, nothing has pissed me off more than the cooling system; namely the heater hoses. If you have ever tried to remove the clamps on the firewall bulkhead, you know what I mean. My GOD that is a pita with the engine in place. lsdkfjlasdkjfasljfa;lsdkjfas;l
Here is the rad hose I made. I found a hose at napa that had some bends I wanted in it so I used that and some of the stock hose with a couple pieces of 1.5in pipe to connect them all together. Turned out like this. Pic doesn't show it but I did put hose clamps on the splices. It's holding water fine so I hope it works lol.
Old Mar 26, 2007 | 02:57 PM
  #87
Tiago's Avatar
LOL
its the little things that get you
Old Mar 26, 2007 | 04:25 PM
  #88
JAvenger007's Avatar
what kind of fittings are those coming off the pump? doesnt look like barb, an, or npt to me.
Old Mar 26, 2007 | 04:46 PM
  #89
Speed's Avatar
They are all NPT and barb. Screw Lowes or Home Depot for brass fittings. Ace hardware has 10000000000000000000000 of them. The pump has 3/8s male NPT fittings on the inlet and outlet. I don't remember exactly what I used (put it all together standing in the store). On the inlet side, there are two 5/8 barb to 3/8 npt male elbows going into a 3/8 female tee. Then it connects to the pump via a male/female 3/8s npt elbow. Outlet is a female 3/8s npt coupler to a male 3/8s npt to 5/8s barb. Another 3/8s npt to 5/8s barb is installed in the oil cap.
Old Mar 26, 2007 | 07:37 PM
  #90
solobaric's Avatar
Subscribing!!!!!!!!!!!!
Old Mar 28, 2007 | 08:59 AM
  #91
Speed's Avatar
I love seeing the "subscribing" posts lol. Sometimes I wonder if anyone besides Chris and Tiago is watch this.
Anyway, got some great news!!! The turbos are spinning!!!!! I finished the y-pipe and essentially the catback. I made a cutout and installed a qtec I bought a while back. More pics:
Here is the bottom of the crossover. You might think by looking at it that it hangs really low but I left part of the stock y-pipe in place to show a reference. What you can't see is how low the original passenger side cat hangs. We lost no ground clearance on the crossover and less than an inch on the y-pipe.
Crossover on the stock drivers side manifold
Passenger side log
Primary turbo
Secondary turbo
y-pipe with cutout (cutout flange not installed yet)
With Q-Tec
On the car
I was playing with the control valve and it's pretty freaky to hear one turbo spinning up slower than the second one. Creates some strange sounding harmonics!
Anyway, I am going to have an exhaust shop I know make a slip fit flange for me so I can take the y-pipe off easier if I need to (all these projects require taking crap on and off and on and off).
I have one issue in that at full pressure, oil was spilling into the secondary turbine housing. I bought a brass needle valve from Ace to try and it appears to be working great! Just had to slow that oil down a bit. I might lower the scavenge pump a bit too since the secondary turbo ended up lower than I originally planned for.
Next comes the cold side build and boost!
Old Mar 28, 2007 | 09:22 AM
  #92
Tiago's Avatar
That is bad *** Bryan,
do you have any pictures of the diverter valve?
why not just install vbands into teh exhaust for easy R&R.
Old Mar 28, 2007 | 09:40 AM
  #93
Superman09's Avatar
LS1Tech Sponsor
Looking good! I have the exact same scavenge pump, working well so far, just a bit noisey. When cutouts closed and exhaust is ran out back, you can hear the pump at idle but once you get moving the engine drowns it out. With cutouts open, you cant hear it. Where is it you mounted yours?
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Mar 28, 2007 | 11:40 AM
  #94
Speed's Avatar
Thanks man. I might have a class in Houston this summer and if this thing is put together right I might just drive it down and have a little fun!
The only thing I have specifically of the diverter valve is a couple crappy videos explaining the operation that I deleted because they sucked lol. Hopefully I can show it to you first hand soon!
I ran out of 3in v-band kits but a slip fit for the back side to joint the rest of the exhaust just behind that S curve should work. I'll have to drop that whole assembly but that isn't very hard.
Thanks! Actually I think it was one of your threads that I found that pump in lol. It's sitting just in front of the front passenger side tire. You can see it in the back ground of the secondary turbo pic above and kind of get an idea of where it's at.
It is a noisy little beast for sure but I can't hear it at all with the open down pipe. I hope it's not too bad with everything quiet. I even thought about running it at a slower speed waaaaaay back when I thought it was going to pump more than the oil feeds were putting in. Yeah, starting it yesterday scrapped that idea!
Old Mar 28, 2007 | 11:48 AM
  #95
SSilverSSurfer's Avatar
wow that looks good, hard work paying off
Old Mar 28, 2007 | 06:34 PM
  #96
Cant wait to see this in action! Your setup deserves its own promo video.
yea ACE has a great selection. I spent a good 2 hours in there constructing fittings on the floor. Ive got the same reverso pump but i simplified the fittings to just a pair of 90* 3/8" NPT female to female and then put in 3/8" NPT male to 1/2" barb in each of those.
Also interested in that diverter valve. Got a part # for it? Where is it installed exactly?
Old Mar 28, 2007 | 08:26 PM
  #97
AmericanMuscle313's Avatar
subscribing
Old Mar 28, 2007 | 09:29 PM
  #98
navymitch12's Avatar
man this is turning out sweet!
cant wait to see it finished!
Old Mar 28, 2007 | 09:56 PM
  #99
Malicious's Avatar
You're too smart for your own good, B
Old Mar 28, 2007 | 11:13 PM
  #100
Frost's Avatar
SPEED!!! I don't know how I missed this ENTIRE THREAD until now... NICE WORK. I'm digging the controls design too
