Hot Side Help?
Old Jan 14, 2007 | 04:12 PM
MetallicaMatt's Avatar
Default Hot Side Help?
hey guys, I'm working on building a hot side for a car. Single turbo, using 2.5" stainless.
I want to merge the 2 sides together using a y-pipe type connector. I found one at Burns Stainless, which will convert the 2, 2.5" pipes, into 1, 2.5" pipes.
heres the link: 2 into 1
for $181!!!!
NOW, can someone direct me to a company which has this same setup, sizes, stainless?? I want to beable to buy one, I don't want to make one myself, anybody got any advice?
heres my second question ---from that y-pipe, I'm going to try and make that all one piece to the turbo. So there will be 3 pieces to the hot side. The y-pipe, and a drivers side and passengers side tubing to the y-pipe. I hope that makes sense. My question is, how would I connect the 2 pipes to the y-pipe? Can I just use a slip fit like its designed for? I would think I'd get leaks?
the reason I'm not welding it together is because I think it'd make it a HUGE PITA to take off in one piece if I need to work on something. So how do you guys connect your hot sides? you can't all be welding everything into one piece?
I'm going to ceramic coat everything as well, inside and out.
thanks for helping out the DYI guy!
Old Jan 14, 2007 | 04:18 PM
JBrady's Avatar
The only list a 3-1 and 4-1 but will build whatever you need. Probably $90-100
http://www.mazzurisuper.com/shop/htm...rgeCollectors/
Old Jan 14, 2007 | 04:22 PM
02SSLE's Avatar
I have hotside parts for sale for fbody if your interested.
Old Jan 14, 2007 | 04:32 PM
Ping King's Avatar
you can make your own merge...its not that hard to be honest..just some careful cuts
Old Jan 14, 2007 | 05:15 PM
JBrady, thanks for the link
02SSLE you have a PM
Ping King, I figured I could make one, but I've got a bunch of other projects to do, including a second copy of this one to do. rather buy this piece than make a half *** one lol
Old Jan 15, 2007 | 12:32 PM
RealQuick's Avatar
http://store.racing-solutions.org/2to1.html
Old Jan 15, 2007 | 12:36 PM
Firechikn's Avatar
Use v band clamps and flanges to connect the pieces. Easy on and off. Gets expensive though.
Old Jan 15, 2007 | 04:18 PM
Originally Posted by RealQuick
nice site. they want $18 to ship one of them. why can't people use USPS lol
oh well, beats $181....
I was thinking about V-bands but like you said, it gets expensive quickly
Old Jan 15, 2007 | 05:21 PM
1fstTA's Avatar
man you will be so much happier if you use the v bands it makes it easy as **** to take everything off and put back on when you got to work on your stuff.
