New Dyno Numbers for the STS
Went to see billy at TRTturbo this past weekend to get a "little" work done on the car...after getting there i noticed i got my taxes back so i had them do a little more work and check out my tune (which we decided it would be best to touch up) So after wrapping the exhaust, remounting the turbo, lowering the boost 3psi, and having Dustin At TRT retune the car i ended up with......
This
MORE POWER WITH 3PSI LESS...and the car is 100x more responsive it feels like the power comes on right away and just gets better with the rpm's. Even if i start out at like 2500rpm and give it gas it does not feel "slow" like it used to. And he moved the turbo up way higher, its now where it should be! Here are some before and after pics of that.
Before
After
That is crazy lean. I run 10.5-11.5 to 1 when under full boost liek that. I would be careful
is your car an m6 or a4
nice #s
We dont really want to go over 500rwhp on stock lower end motors. I know some do, but we usually stay on the conservative side. Mitch has a cam, t-67, 6 speed, so we lowered the boost to keep it at a resonable level. Plus, after looking at the tune, we knew it had much more in it.
