Official STS help thread
Old Mar 16, 2007 | 02:19 PM
koolaid_kid's Avatar
Just be prepared to make some mods. The stock setup is too low, but is easily fixed. The power is good, and easily adjusted.
Old Mar 16, 2007 | 02:22 PM
Originally Posted by GR33N GoblinM6
here is the biggest help and best advice i can give on STS..
DONT BUY IT UNLESS YOU LIKE PROBLEMS AND HEADACHES...
and thats my opinion..
Actually, that is not an opinion, it is a judgement. GL, GR33N.
Old Mar 16, 2007 | 02:46 PM
Schantin's Avatar
Originally Posted by ZL1Killa
i see in the picture above and I don't mean to change the subject, but where in the hell do yall find these upper radiator supports? i can only find the one that BMR makes...and I don't like it cuz it has two humps.... lol. I want the one hump at the radiator and then smooth to the body like above.. cuz I want to paint on a Black bird centered on it
The radiator support is from the K&N FIPKII. When I installed the turbo, I cut the mounting tab off the cover that the K&N filter bolted to. Thats probably why you're having a hard time finding it. A LT1 upper cover will work fine. That's like the BMR one.
Hope this helps.
BTW, wouldn't worry about "changing the topic". Heaven forbid useful info is passed here vs stupid comments from haters and experts that have probably never seen an STS car in person
Old Mar 16, 2007 | 04:55 PM
JDP's Avatar
JDP
Originally Posted by trans2000am
oh yea im pretty sure me and you will be running each other about a thousand times this summer,hopefully my rearend will hold up
dont you two girlies forget about me.
just a little 346 n/a for JDP to hand ryans *** to him.
im just playing, we are all suppose to be on the same team, right?
MUSTANGS FTL!!!!!11111one
can wait to see your car done ryan, and als, and chads...
and mine, lol. LS1s should rule this year
Old Mar 17, 2007 | 10:23 AM
trans2000am's Avatar
are you going with the donkey dick cam? weird name for a cam,you should get that on ur back window or license plate
Old Mar 17, 2007 | 11:24 AM
99Z28LS1's Avatar
Originally Posted by losiguy
Good numbers on 5.5 PSI though. Stock Motor? TRT has there **** togethor.
thank you, i didnt mean the i didnt know you guys knew each other..... but yes, everything is stock other than pulley, injectors and LT and ORY. i also have their cam that would get me more power but im scared about the bottom end
Old Mar 17, 2007 | 11:27 AM
99Z28LS1's Avatar
Hope this helps.
no doubt, i've shut several people up at the races that thought NAAAWWWWZZZZ was the only way to go after i won i told them to fill their bottle up all the way for the next race
Old Mar 17, 2007 | 11:31 AM
rudyzturbota's Avatar
so whats this rumor about abanding all rearmount turbo cars at the track, if this is the case i guess i will have to make my rearmount a frontmount, what have u guys heard about this?
Old Mar 17, 2007 | 04:34 PM
IROC403's Avatar
hi, were installing the sts kit on a 98 ws6. (used-no instructions)mostly done thanks to you guys. my question is -on the blue blow off valve in the front theres a 3 foot cut
1/4 vac line. any ideas on what it does???vent maybe?? thanks, ken
Old Mar 17, 2007 | 05:38 PM
unit213's Avatar
Administrator
Mustangs FT...what? Allen Park is 10 minutes away.
Old Mar 17, 2007 | 05:59 PM
JDP's Avatar
JDP
did i stutter.
just kidding, if you want to get in on the fun unit, its cool. im down to race my first cobra with my bird. only cars i ever get to race is other ls1s.
chad says he knows you. because you take your **** to livernois.
no ryan, im probably going with a custom grind, not sure yet what direction im going to take. but ill give your little sts kit a run.
Old Mar 17, 2007 | 06:33 PM
  #32
99Z28LS1's Avatar
sick car and sick vid in the sig
Old Mar 17, 2007 | 07:52 PM
  #33
JD_Z28's Avatar
Its for vacum. Hook that line into your blow off valve and then into a vacum source such as your brake booster.
Old Mar 17, 2007 | 07:57 PM
  #34
99Z28LS1's Avatar
be careful how close you get the line next to your headers.... if your headers are coated then you done really have to worry baout melting the line..... i've had my line to the BOV melt due to heat of the headers.
Old Mar 17, 2007 | 08:47 PM
  #35
IROC403's Avatar
thanks, i noticed a port on the waste gate also, not the pressure one,but on the side.
some pics are left open but some have a valve with a wire on it atached to it,
any ideas?????????? thanks again, this site rocks!!!!!!!!!!
Old Mar 17, 2007 | 08:54 PM
  #36
JD_Z28's Avatar
Edit.....
  #37
trtturbo's Avatar
the port on the side (opening closest to the bolts that hold the top on) is for your boost reference. If you have an intercooler, you should run a vacume line from the wastegate to an intake vacume source. If not, then from the outlet on the compressor housing to the side of the wastegate.
The top port is for a boost controller.
Old Mar 19, 2007 | 01:15 PM
  #38
anybody have meth install instructions mine never came with them when bought from sts, they faxed me over some but,they are confusing maybe some pics of install would help.
Old Mar 19, 2007 | 03:17 PM
  #39
99Z28LS1's Avatar
you might be able to contact snow performance on instructions..... i didnt think that the STS manual came with meth intallation instructions...... maybe my manual is outdated?
Old Mar 19, 2007 | 04:19 PM
  #40
Eatinstang4life's Avatar
Did you mean if he has a boost contoller to run a vacume line instead of intercooler?
