LSX block work moving forward
Old May 15, 2007 | 03:41 PM
427's Avatar
427
Default LSX block work moving forward
We are almost ready to start honing blocks! We have the proper torque plate now and ARP is working on getting us the right studs, nuts and washers to tighten the plate down. We have filled one block and some of the rough boring process is already started. I can't wait to get one of these in the car!!
Kurt
Attached Thumbnails LSX block work moving forward-2007_0515lsx-torque-plate0001.jpg
Old May 15, 2007 | 04:04 PM
Tiago's Avatar
awesome
Old May 15, 2007 | 04:27 PM
FSTR-THANU's Avatar
Outlaw 10.5 Director
Old May 15, 2007 | 04:30 PM
Noyzee's Avatar
8 second mod
mine is getting worked on as we speek. i cant wait either!!!
Old May 15, 2007 | 05:12 PM
98turbls1's Avatar
Are you using a different torque plate for different bores or using the one for all of them?? I know that it's a dumb question but I live by the rule of "there are no dumb questions if it's an honest one"... Either way, looks good and can't wait to see some numbers... You guys rock...
Old May 15, 2007 | 06:06 PM
FSTR-THANU's Avatar
The plates are usually designed with the max bore condition in mind.
Tom
Old May 15, 2007 | 06:38 PM
NemeSS's Avatar
so the LSx block cant be honed with a conventional tq plate
for a gen 3 block, like the one most machine shops have now?
still though, forward progress
Old May 15, 2007 | 10:14 PM
427's Avatar
427
Thats a fair question. We have 4 plates with different bores on 3 of them. You need the plate bore to be close to what you are using to simulate the stress of the heads you will run when the engine is finished. We use the gasket and fasteners that will be used when the engine runs whenever possible, this brings the cylinder into the conditions it will "work" in.
All of our LSX blocks will be around 4.125 and our plate is 4.150 bore to clear the stones.
Kurt
Old May 15, 2007 | 10:17 PM
427's Avatar
427
We think for the best results/power possible, it should be torque plate honed as close to the way it is used as possible. Our customers are going to stress these blocks to the limit, right Tom??
Kurt
qqwqeqwrqwqtq's Avatar
Looks nice Kurt. Are you planning on running larger diameter fasteners or what the block came machined for?
Old May 15, 2007 | 10:19 PM
427's Avatar
427
Larger than factory equipped on all fasteners....
Kurt
Old May 16, 2007 | 07:55 AM
FSTR-THANU's Avatar
Kurt
If 200mph on a radial is considered stressing the block then "YES I AM".
Tom
Old May 16, 2007 | 10:02 AM
52172's Avatar
why are you only going to 4.125 bore when the block will go to 4.25? Just wondering.
Old May 16, 2007 | 10:30 AM
Tiago's Avatar
to use all of its 2500 hp rating, the 4.25" bore is probably not advisable
Old May 16, 2007 | 10:36 AM
black98ws6ta's Avatar
Leaving some material there for strength and we dont need huge ci motors to make power.
Old May 16, 2007 | 10:45 AM
52172's Avatar
Gotcha that is what I might have suspected. What bore do they come with?
Old May 16, 2007 | 10:46 AM
427's Avatar
427
4.250 is a marketing number. If that is ever done, it will probably be a NA engine that is problematic.
We are looking to supply durable power adder engines with 4 digit power, on a few of them the first digit will probably be a "2". This requires that the overall package be safe first, and leave some room for repairs/rebuilds in the future. Besides if you have ever seen Tom's crew at work, you would know why we build strength into every engine!
200mph on radials!! Thats what I'm talking about!! When you do it, look over into the other lane, in my dreams I'm there(slightly ahead of you)!
Kurt
Old May 16, 2007 | 11:20 AM
52172's Avatar
what kind of stroke are you guys gonna run? Twin turbo?
Old May 16, 2007 | 11:49 AM
427's Avatar
427
Three will be 4 inch, the other two are undecided, but 4 inch is likely. They will all be turbo, one for sure will have two 67mm Turbonetics unit
Kurt
Old May 16, 2007 | 11:57 AM
Bad30th's Avatar
Way to be on the cutting edge W2W ! These blocks are gonna make some killer power.
Rob (Bad30th)
