Boost on 11.6:1 C/R
Old May 29, 2007 | 05:57 PM
LostCauseZ06's Avatar
Default Boost on 11.6:1 C/R
alright i have a slightly stupid question. I have recently been bitten by the turbo bug. i HAVE to have a turbo but i really dont want to swap out my pistons.
How much boost could i get by running on my forged 408 with a high C/R??? any ideas?
Old May 29, 2007 | 06:00 PM
sprayjunkie's Avatar
I would pose this question directly to your engine builder and your tuner.
Old May 29, 2007 | 06:01 PM
Retail Value's Avatar
no more than 5 psi on a VERY VERY VERY conservative tune...
Old May 29, 2007 | 06:07 PM
ls1CANTU's Avatar
would like to know this too.
Old May 29, 2007 | 06:15 PM
HUNTER02SS's Avatar
You could probably run more than 5psi, but you would have to run race fuel with it all the time and no timing I would guess.Not sure though,but you can just buy a set of head's with bigger chamber's and run some thick head gasket's also to help lower the compression.IMOA
Old May 29, 2007 | 06:16 PM
KAOS's Avatar
subscribing. with race gas how much boost can you run with that high of compression. and what would be the outcome, blown head gaskets?
Old May 29, 2007 | 06:23 PM
HUNTER02SS's Avatar
If it was my setup i would run 10lbs of boost and the race gas and play with the timing,but I would not go over 10lbs.What is the stock compression like 10.5 or close to it,so it is not that far off of stock.That is what I would do if it was my car but I like the extreme of thing's anyway.
Ping King's Avatar
theres a few e85 stations in your area...i would take a look at running e 85
Old May 29, 2007 | 06:39 PM
Lythropus's Avatar
I'm going to say 6 pounds for over 100 horsepower again, don't do it, you won't make as much as with nitrous and it will be more prone to detonation...
Old May 29, 2007 | 06:48 PM
ALTRDTA's Avatar
I say do it Chase and see what you can get out of it. You have the money just burning a hole in your pocket so go for it.... Don't be scared. lol
Old May 29, 2007 | 07:00 PM
cws T/A's Avatar
http://musclemustangfastfords.com/te...pression_ratio
Old May 29, 2007 | 07:22 PM
HUNTER02SS's Avatar
After reading that I woould say boost the hell out of and see what happen's ,especially if have the $ to build another engine if this one on you!!
Old May 29, 2007 | 08:22 PM
Speed's Avatar
How much boost at what octane will be an exercise of trial and error. You obviously will be much more limited, you will extract more power for a given air flow vs a low compression engine. If I had to guess, I would say 10psi on 118 with 15* or so of timing will net you very respectable results. Meth/water injection will help stabilize the mixture if you are picking up knock.
Be vewy vewy cafull and take it slow.
Old May 31, 2007 | 09:07 AM
Bad30th's Avatar
I was making 5-6psi on 11.6:1 on (mostly) 91 octane pump gas for a while before I got new heads. I just pulled the timing back a little and ran a little race gas for extra insurance. It ran great and pulled hard, and it was on the stock bottom end too with a 222/224 cam on a 114 LSA.
I'd buy some larger chambered heads to lower compression before I swapped pistons, seems like a lot less work...
Rob (Bad30th)
Old May 31, 2007 | 09:12 AM
smokinHawk's Avatar
man i sware i just locked one of these
your gonna have to tune and see, there is no set psi to CR to many varilbes
https://ls1tech.com/forums/forced-induction/208864-turbo-faq.html
