boost on and off
Old May 31, 2007 | 02:32 PM
Sopcich04's Avatar
Default boost on and off
can u turn boost on and off with a Procharger? also would it be pointless to have a twin procharger setup or can one do the job. can u adjust your boost? i want max 20psi but want to be able to adjust it, thank you!
Old May 31, 2007 | 02:38 PM
6techniques's Avatar
sure, if you want it turned off, just remove the pulley and drive like that...Or dont drive the car at all.
One will get the job done as they have models that cover just about all hp ranges...When you see a twin s/c setup, in most cases its just for show.
Do some more research on centrif. s/c's as its obvious that you need to learn more about them...the size of the pulleys dictate how much psi you run.
Old May 31, 2007 | 02:43 PM
kbronSS's Avatar
i think u have them confused with turbos.......no?
Old May 31, 2007 | 02:46 PM
Sopcich04's Avatar
dang, well i have done research on all types of SCs and the cent. one looks like a turbo haha so u never know. well that sucks cuz turbos look confusing as hell to me. maybe ill figure it out before i finish building my engine
Old May 31, 2007 | 03:42 PM
mdhmi's Avatar
You can adjust boost with a centrifugal supercharger.
You simply adjust your RPM (short-shift) or swap out your supercharger pulley (the larger the pulley diameter the lower the boost).
Old May 31, 2007 | 03:50 PM
daniel6718's Avatar
lol at this
Old May 31, 2007 | 03:54 PM
mdhmi's Avatar
Originally Posted by daniel6718
lol at this
Yea, I know - this is really pathetic.
Old May 31, 2007 | 03:56 PM
kbronSS's Avatar
lol at this
Old May 31, 2007 | 04:40 PM
otherwhitemeat's Avatar
to change boost level with a s/c you can use a dump valve .
Old May 31, 2007 | 10:00 PM
Sopcich04's Avatar
hey jerks i dont know, im not use to small engines that need force induction hahaha
i guess if i really wanted to **** someone off id just post the link to that 2jz in a camaro link
Old May 31, 2007 | 10:47 PM
kbronSS's Avatar
why dont u just go over to speedinc?? if im not mistaken, they are in chicago too.
