corvette twin turbo
Old Jul 15, 2007 | 07:27 PM
  #81
2000Z28ls1's Avatar
This is pretty sweet thanks for updating us with every detail. Kinda like learning how to do it better myself as you go awesome looking project even though I'm kinda more a Black and white kinda guy for but the red and blue looks clean
Old Jul 16, 2007 | 10:18 AM
  #82
hellbents10's Avatar
LS1Tech Sponsor
As long as you get the correct injector size in he can go to a shop and get it tuned. Just stay out of boost.
Old Jul 16, 2007 | 03:56 PM
  #83
Cheatin' Chad's Avatar
I was under the impression that full welds on the tubing side of the flange was a no-no due to cracking from expansion/contraction. Have I been given bad info?
Old Jul 16, 2007 | 05:45 PM
  #84
Inspector12's Avatar
TT-TECH Veteran
Originally Posted by presto_z
today he tapped and ran all of his oil lines.. this thing should be finished really soon, there are only a handfull of things to finish up like running the intercooler piping, hooking up the catch cans, and a few more odds and ends befor he gets the tune...
he has a programmer for his old vortech system, that changes the tuning for the bigger injectors and for running boost (would he be able to use that to get the car to the shop for the tune? or will he need it trailered) it seems like it would work doesnt it??
Only will work if it is the same injectors used in the vortech kit. All injectors are just a little different and will require a specific table usually for that particular injector not to say that it won't run, but it still might be Very rich or Lean if it is a different injector other than the ones that came with the Vortech kit. It still might serve his purpose, but I'd take the PC over and have them load a good injector table for the one's you purchased atleast. Good luck.
Old Jul 16, 2007 | 09:52 PM
  #85
nick y's Avatar
Originally Posted by DrTurbo
Good luck with those chinese turbos as well....lol. They should make some cool paper weights after a few hundred miles.
correct!!
so ****** outa balance......i only givem 10 days
Old Jul 17, 2007 | 09:26 PM
  #86
presto_z's Avatar
we still cant figure these out..ugh
does anybody know where these go?? the kit is supposed to come with an alternator relocation bracket(s) but were not sure if they forgot to send it or if it is made up of these pieces
piece1
piece 2
and piece 3
some of the holes on piece 1 line up on the water pump, but we are not sure exactly what it does
piece 2 dunno and piece 3 is some sort of bushing or something
any help or input would be greatly appreciated
Old Jul 17, 2007 | 11:01 PM
  #87
Red99C5's Avatar
Did you give the stainless headers the magnet test? I'm just curious if there are 416 or 304 stainless.
Old Jul 17, 2007 | 11:11 PM
  #88
52172's Avatar
that is a very good question. Me being a Hi-Flo piece of **** Marko customer found out the hard way that false advertising is not that difficult. They advertised pure stainless 321 hot and cold side and after a year wait they shipped pure 321 tubular manifolds being pure 321 stainless, but the flanges were steel and the crossover was indeed pure 321 stainless. There is nothing better than the magnet test to prove false advertising.
Old Jul 18, 2007 | 09:06 PM
  #89
presto_z's Avatar
Originally Posted by Whistler
The price he paid for this kit was unreal. Even if the turbochargers are garbage, the hot parts alone were well worth the price.
I didn't get to see the intercooler, but the headers and downpipe were well built. TIG welded 304 stainless, with the internal passages ground and sandpaper rolled.
there ya go
Old Jul 19, 2007 | 08:37 PM
  #90
XJGPN's Avatar
Have no first hand experience on C5 vettes so no idea specifically what/where it is for... but they look like exhaust hanger pieces.
Old Jul 19, 2007 | 09:14 PM
  #91
presto_z's Avatar
thats exactly what i said.. but this kit bolts strait up to the stock exaust, so they really wouldnt be needed...
well he ordered a halltech 90 alternator and a halltech alternator bracket, so these are no longer gonna be used... he is just waiting for these items and he is pretty much done, all of his oil lines are ran, the injectors came in today, he still has to mount the catch cans, but thats a pretty easy task.. (is still gonna need a tune.. mike norris (sponsor and one of the top tuners in FL) has a dyno tune in town this weekend, but he wont be able to make it since he wont have the alternator and bracket in time (also the boosta pump)
this install took quite awhile, because he only got to work on it for 2 hours a night, in a normal home garage with basic hand tools and no lift.. plus he painted all that stuff and had to wait for **** in the mail...
now that its been done once, if he/or i ever had to do one again, it would be alot easier since all the hard stuff (figuring out how everything goes without instructions has now been done)
if anybody else needs assistance with this kit just ask and ill do my best to answer (i have a **** ton of pics), if i cant help ya ill ask Chris(guy who owns the vette) and he should be able to (has alot of pics too)... ive learned quite a bit about turbo's and turbo installs since this project went underway, and now my install should be much much easier..
stay posted for finished pics, and hopefully within the next few weeks for some numbers (hopefully around 525 rwhp) catback only car.. and the twin turbos of course..
Old Jul 20, 2007 | 01:12 PM
  #92
XJGPN's Avatar
True, but the exhaust is now going to extend up past the engine to the turbos... so there might be a location on that run. Also, a lot of turbo companies will add an exhaust hanger near the turbo so that all that weight isn't just hanging off the manifolds. Just something to check into.
Old Jul 20, 2007 | 05:52 PM
  #93
presto_z's Avatar
XJGPN thanks for the info, ill check into that..
well some more progress to report
his new alternator came in and it is sweet
this thing puts out alot more power then the stock one, and is alot smaller too
the catch can he purchased for the power steering fluid resivior was to big, so a quick stop at a local welder and it was cut down to size
here is a pic of the new one side by side of one being used for the wiper fluid.. they were once identical
he had to slightly modify his abs bracket to lower it just a nudge, he cut the nipple off the bottom and trimmed off some access metal that wasnt letting it lower enough
and he made the notches bigger so he can fully lower it
hopefully he will have it all finished up this Sunday with a partial tune, and a full dyno tune as soon as mike Norris or Jeremy formatto come back into town
Old Jul 22, 2007 | 02:12 PM
  #94
chriswtx's Avatar
Old Jul 22, 2007 | 02:17 PM
  #95
xtremejimmy's Avatar
i just realized you guys are located here in south florida! Where do you guys stay at! I would love to take a look at the final product it its ok! I would probably buy a kit if this looks good to me in person!
Old Jul 22, 2007 | 03:01 PM
  #96
presto_z's Avatar
Charlotte county, in between ft. myers and Sarasota
well the alternator wont work, its the wrong model so he has to send it back and get the right one so looks like it will be a few more days before its finished and he also decided to lower the ABS a little more so its further away from all the heat..
Old Jul 22, 2007 | 03:55 PM
  #97
99Fbody99's Avatar
More toys!!
Has your buddy added up all the damages for the additional stuff needed to complete it. A friend of mine wound up selling his ebay kit on the CF after figureing out he would have atleast an additional $3,500+ (and a fair amount of fabwork)into it before it was all said and done.
Dave
Old Jul 22, 2007 | 04:03 PM
  #98
52172's Avatar
the damages are at least 3500 for the fuel system, gauges, misc extra parts, FI is not cheap no matter how you go about doing it. I spent 17K to go turbo and I got a great deal on my kit for only 4300 including the turbo. I also put in a new clutch and fresh short block.
Old Jul 22, 2007 | 04:43 PM
  #99
Fastbird93's Avatar
Old Jul 22, 2007 | 05:34 PM
  #100
presto_z's Avatar
he quit adding it up after the 400 dollar alternator lol... he will still have alot less into it then going with a different kit though
i figure for my camaro kit ill have around 4k from start to finish including including all the fuel upgrades, guages, misc parts and dyno tune...
