How much boost???
Old Jun 23, 2007 | 09:57 AM
Nightrydass's Avatar
Default How much boost???
How much boost can the stock bottom end of an LS1 handle? Im this will be a steet car with some track time, but not like every weekend.
i deciding on if i want to buy a crate motor or beef up my top-end and slap on a procharger. However, I'm buyin headers next yr and only want to buy them once, so i need to make sure i get the right ones, and the "right ones" depend on weither i decide to go with a crate or a SC.
the car currently has 83K miles on it, and some piston slap (tho not that bad).
Old Jun 23, 2007 | 10:04 AM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
I give you 8 psi on a stock bottom end. Some run maybe 2 more psi on a stock bottom end with a safe tune (me).
Old Jun 23, 2007 | 10:37 AM
i read that sticky "the tru cost of forced induction" and most of it pertains to turbo's... does it cost just as much (potentially) to have a SC also...to do it right that is in order to prevent my motor from going into orbit?
Old Jun 23, 2007 | 10:49 AM
nvmy2000ss's Avatar
Both are expensive.
Old Jun 23, 2007 | 11:10 AM
Originally Posted by nvmy2000ss
Both are expensive.
son-of-a....
i just want to kno so i dont get a different impression and end up over my head. I would want to do it RIGHT. And do it RIGHT the first time. Im not one to cut corners and half *** things.
so they are both the same amount (around)? In other words the "optional" and "required" items listed in that sticky apply to turbos and sc'ers?
i just want to make sure i have a clear idea what what is involved
Old Jun 23, 2007 | 11:39 AM
Have a lot of cash available because 10 grand will go like a cold Red Bull in the summer.
Old Jun 23, 2007 | 12:02 PM
o damnit, scratch this idea then. i guess it is a crate and NOS for me then.
Old Jun 23, 2007 | 12:11 PM
FieroZ34's Avatar
The stock LS1 bottom end can handle a nearly infinite amount of boost. The only limits are how much can the intake manifold handle before it breaks. So I'd say around 100psi.
Old Jun 23, 2007 | 01:06 PM
fenix999's Avatar
ummm huh...? yea ok
Old Jun 23, 2007 | 01:13 PM
daniel6718's Avatar
boost level i dont think matters..its the resulting hp that limits it...id say around 600-625 is your limit...few nitrous guys have made it to 650 for a little while
Old Jun 23, 2007 | 01:18 PM
FieroZ34's Avatar
We have a winner.
CFM > PSI
Old Jun 25, 2007 | 01:23 PM
Frost's Avatar
?? Good info; way to tell someone something that can hurt their engine, good job there...
8-9 is safe with good tuning; the number 7 ringland will be the first to go if there are issues.
Old Jun 25, 2007 | 04:48 PM
FieroZ34's Avatar
I guarantee you I can have an LS1 make 100psi safely. It may only make 400hp, and may have a 2.5" metal plate blocking 85% of the throttle body, but it will make 100psi.
Watch. I'll borrow your LS1 for a day. I will back the engine with a full guarantee, and I'll also guarantee you will see 100 psig. It will probably be slower than before, but what does that matter?
Old Jun 25, 2007 | 05:58 PM
Zombie's Avatar
I guarantee
I know what you are talking about lol. I hope you have one hell of a fuel system for 100psi lol. Your injectors won't even squirt!
for the OP, about 600 RWHP seems to be the edge on the stock bottom end. Some make more with great success, some make less with disaterous results.
I personally made over 600+ for quite a while.
Old Jun 25, 2007 | 10:58 PM
FieroZ34's Avatar
Well, that depends on where the 100psi is at. If it was where I was thinking (At the throttle body), then that is the flow restriction, and the intake manifold will only see the PSI required for 400 or so hp, meaning they will fire perfectly normally. However if the restriction is in the valves or heads, then yes, the injectors may have trouble operating correctly.
Old Jun 25, 2007 | 11:14 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
FieroZ34, we all understand your point about psi vs cfm. However, I feel that you are doing a great injustice to some of the beginners here. Leave the fluid and thermodynamics disussions in the advanced section, and let the "simple" questions be dealt with simply. The original poster obviously has a near stock motor, in which case 8-10psi would be pushing it. We can all throw out simulated variables for almost any situation. but that is irrelevant in the main forums. Since you are intelligent enough to understand that life isn't as simple as people would like, please explain your answers better, or put them in the advanced forum where everyone should already understand.
Old Jun 25, 2007 | 11:23 PM
FieroZ34's Avatar
We have no idea what his engine is. All he said was a stock bottom end. So what are we left to assume? If his entire motor was stock, he would have said so. But he only said stock short block. So I'm assuming the long block components aren't stock, like it's a head/cam/intake car, like most of the cars on this forum. Thus his VE is most likely above 90%, meaning 8-10psi is A LOT, and probably pushing over 550hp as it is.
If this stuff is to complicated for him, he needs a new hobby.
Old Jun 25, 2007 | 11:30 PM
stoverz28's Avatar
Correct me if im wrong but i was under the impression that the procharger kit is a "complete" kit meaning not much hidden costs as far as getting the supercharger system installed and operating. Now getting your drivetrain to take the abuse is a completly different story.
