IAT sensor and boost
Old Jul 24, 2007 | 08:05 PM
Gold Phoenix's Avatar
Default IAT sensor and boost
First of all, the search engine sucks. I am not getting the results for the most easy topic and I am getting posts from years ago.
OK, I am concerned that the IAT sensor getting blown out with my F1R. I need to know if my concern is justified and some alternative designs.
Old Jul 24, 2007 | 08:06 PM
T/A KID's Avatar
Get a Threaded IAT from FAST, and it uses a 3/8 bung. Problem solved.
Old Jul 24, 2007 | 08:07 PM
JMBLOWNWS6's Avatar
Speed INC sells the setup you are looking for. Ive had cars up to 16 psi not push out the rubber one.
Old Jul 24, 2007 | 08:11 PM
OK, where is it on their website? I guess I could take a stock one a epoxy it into the pipe.
Old Jul 24, 2007 | 08:30 PM
onfire's Avatar
Coal Mining Director
I've used both. If the grommet is in properly it's not coming out under boost.
Old Jul 24, 2007 | 08:32 PM
HUNTER02SS's Avatar
I agree. I have had no problem's either.
Old Jul 24, 2007 | 08:35 PM
Is there any specific way that is best? What size hole should I drill in my pressure pipe?
Old Jul 25, 2007 | 08:23 AM
ls1290's Avatar
Dumb Ass Vette Moderator
If the IAT sensor is placed in a metal pipe and the hole is sized correctly, it should stay in place even at 30 PSI. I have seen many IAT sensors come out that are mounted in the silicon couplers. It is bad to mount it there because the silicon is not ridged enough to hold is shape over 4 or 5 PSI. The silicon just flexes too much.
Keith
Old Jul 25, 2007 | 10:02 AM
NoGo's Avatar
I just got rid of mine and put a resistor in the IAT. 3bar OL-SD tune here.
Old Jul 25, 2007 | 10:10 AM
onfire's Avatar
3bar olsd here also. But I like to use mine to drop timing at he big end as the iat's come up.
