Building a magnacharged LS1 from scratch
[list][*]How much total hp can be made by the magnacharger?[*]Will the 346 be enough, or should we go with a stroker to maximize the supercharger? Advise on brand?[*]Compression?[*]Stock heads? Port work? New heads?[*]Computer? (we were thinking F.A.S.T.)[*]Ignition?[*]What cam will work good with this combo?
Basicly, if you were building this engine, what would you do? We need specifics too, "a strong cam and stout bottom end would work well" wont help us too much, we need details, brands, ect.
Thanks, hope you guys can help us LSx engine novices out!
if you just did a head/cam swap you would be over 500 hp and most SC kits are making 450+ RWHP on stock engines....
it almost sounds like you have more money than you know what to do with.....aftermarket computer and ignition....a stroker.....
if I were doing this, I would do the following:
- stock short block (replace pistons)
- port/polish 6.0 Liter heads with 2.08/1.60 valves (will flow better and lower CR some)
- get compression somewhere between 8.5 and 9.5 ???
- stock computer (reporgramed) and ignition
- magnacharger
if I were to guess, that would be well over 600 hp....perhaps even 700 hp with the right pulley
The reason I asked about a stroker is because I thought we would have to go with an aftermarket bottom end anyways. Or can a stock crank handle +800hp?
All we have right now is the longblock, no computer or ignition, so we were just going to go aftermarket.
This is going to be pushing a 2000lb dune buggy, btw.
Thanks, the more specific your input, the better!
I would still use the factory computer and ignition....it works fine and you can probubly get it (and the wires) for less than $500...
The stock crank and rods will take A LOT of hp. Replace ALL the bolt in the engine with studs (rods will use ARP bolts). Then have the press fit pins replaced with floating pins. Finish it off with some low compression forged pistons and you will have a all around good short block.
For the heads, you can use the 5.7 heads you have but really you would do better to get a set of 6.0 Liter heads. They have a larger CC chamber (lower compression more) and they already flow really well. Port/polish and replace the valve with 2.08/1.60 valves and your good to go there.
For a cam, something that has more duration on the exhaust (ex: 230/234) to clear the cylinders. A higher LSA (114 or 116) will make a smoother torgue curve.
I'd stroke it to a 383, get forged dished pistons, forged rods, forged stroker crank. I think the stock ignition and computer could handle this (cheaper too), get some good flowing heads, a big blower cam, LT headers, and all the bolt-ons. You could probably run like 15 pounds of boost (using an intercooler of course) without worry.
With the blower/intercooler, high flow heads, big blower cam, and all that bolt-on stuff in a stroker 383...damn, you'd have mucho power.
Lunati sells a 383 stroker kit/crank that has had good reviews.
I'd say ARE heads, LS6 stage II heads, they seem to be getting good numbers.
You might want to look into a sheetmetal intake (i forget the company, but www.thunderracing.com has some for sale) if you wanna spend bank, otherwise get an LS6 intake manifold (buy anywhere).
C5R Block
forged whatever size crank you need to make a 427
forged h-beam rods
sheet metal intake
MTI stage 3 heads
D-1SC Procharger with intercooler
100 shot after the intercooler
now if it was a budget:
stock block with arp stuff
ls6 intake
383 lunati stroker kit (comes with pistons and rods)
stage 3 heads from absolute
still d1sc procharger with intercooler
Fuel pump: Weldon 2025
Fuel rails: Custom billet
F regulator: Weldon
Injectors: 83 lb Siemens
PCM: imported PCM controller
Block: 3.905 bore LS6 block
Pistons: 9:1 Diamond
To make 800rwhp on 91 octane, your best bet is to get 8:1 - 8.5:1 pistons.
The problem with some blower and turbo setups is they might not be rated to make that kind of power.
I am doing a Vortech YS trim pulleyed for 20 lbs of boost and hope to make about 700rwhp thru an unlocked T400 trans. That's good for mid 9's and about 140mph in the quarter.
