whats the progress or updates on your project?
Old Aug 2, 2007 | 06:00 PM
SSilverSSurfer's Avatar
Default whats the progress or updates on your project?
i havent seen alot of people with updates. just curious as to how your projects are coming along or if theyre finished. i drop my motor off saturday with erik@HKE so im waiting on that. then just some more fuel stuff and i should be installing within the next couple of weeks, hopefully. i will probably drop my parts off with the coater. havent decided yet.
Old Aug 2, 2007 | 06:01 PM
Tiago's Avatar
I'm waiting on Erik@HKE also
Old Aug 2, 2007 | 06:12 PM
turbo_tom's Avatar
My car is never "finished"...
Next on the agenda is probably meth injection, a new hood, and a short shifter. I'd be happy to have that done by the end of the season. Still need to swap in a built rear, clutch, EBC... I can go on forever. Oh I also have two TurboSmart BOV's on order that Slowboy Racing somehow screwed up...
Old Aug 2, 2007 | 06:44 PM
02NBMFormula's Avatar
should start the blower install next week, already changed the plugs, installed the guages and the fuel pump.
Old Aug 2, 2007 | 06:56 PM
SPRAYED 01's Avatar
I have my turbo setup on a table in my room. Picking up my engine next saturday. Everything goes in first weekend of september. Then tuned as 2 weeks later. Should be back in action in October.
Old Aug 2, 2007 | 07:45 PM
Josh@KY-Turbo's Avatar
My car is back under the knife getting a new drag braks, wheels and tires, 10pt cage, suspension, heads, cam, carb style intake, and a 91mm turbo setup.
Old Aug 2, 2007 | 08:14 PM
kbracing96's Avatar
My turbo is exercised daily
Old Aug 2, 2007 | 08:37 PM
98turbls1's Avatar
Well.... I've been a busy little elf... I finally started on my TH400 conversion... I finally got all my parts and the T56 is out... I got the meziere flexplate, neal chance converter, bmr trak pak (installed), pro stick mocked in (gotta find some better metal to mount it to), finally got an auto console and pedals, and some other stuff.. currently I'm waiting on my JW bellhousing and BMR crossmember which should be about two weeks... I'm also going to a FMIC soon and then it'll be off to tuning (doing it myself) ... I've spent a ridiculous amount just on the swap but I won't have to worry about it once it's said and done...
Old Aug 2, 2007 | 08:46 PM
Got Me SOM's Avatar
**** i'm outta dough. wish i could do an aps kit..
if i could find a 2nd job that pays decent I'd keep my car to make it 1000 hp like I always wanted..
Old Aug 2, 2007 | 09:06 PM
theblur98ss's Avatar
Right now I'm skimping and saving so I can do a T6 setup over the winter. My motor should be ready any time now. I plan to drive it na for the rest of this year.
Old Aug 2, 2007 | 09:08 PM
bowtieman81's Avatar
I am in the process of putting my incon kit on.
https://ls1tech.com/forums/forced-induction/757786-my-incon-install.html
Old Aug 2, 2007 | 09:31 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Doing:
35 spline stuff, spool
Drag brakes front and rear
Splitflow muffler
Parachute mount if there's time
Old Aug 2, 2007 | 09:47 PM
SR-71 SS's Avatar
Car currently at the shop getting the fuel tank sumped, my twin disk clutch is going in as soon as i get the car back, and then back to the dyno and hoping for 600 rwhp
Old Aug 2, 2007 | 11:39 PM
BOONE's Avatar
I dynoed the numbers in my sig on last weekend with my new Nasty fuel system, and intercooler from EPP after what seemed like about a million hours of screwing around.
Old Aug 3, 2007 | 12:18 AM
Inspector12's Avatar
TT-TECH Veteran
Changed the wastegates springs out and reinstalled my methanol and changing the gears this weekend then some further tuning will be the end of the orange car. The black car I have all the pieces back from the machine shop just need a little time to put it all together.
Old Aug 3, 2007 | 12:21 AM
calongo_SS's Avatar
Trying to get the car ready for the APS twins.
Got the gauges in, dual intank fuel pumps in, got the return set-up & rail mount regulator done, 4L80 is in also. Just a few more odds and ends and the car should be ready when the kit gets here.
Old Aug 3, 2007 | 04:42 AM
Rickys S/C Z28's Avatar
im still in iraq trying to plan everything out im still in the work on getting a forged bottom end iv got some paritot 6.0 heads with DG springs and iv made up my mind on a cam(EPP cusyom grind) trying to make the $$ go as far as i can, im trying to stay in a 6k budget so im working hard on getting the most for my $$ but i leave here in about 2 mounth then ill start ordeing parts
Old Aug 3, 2007 | 09:20 AM
ls1290's Avatar
Dumb Ass Vette Moderator
In the process of SD tuning the setup Hopefully it will be done soon.
Keith
Old Aug 3, 2007 | 09:55 AM
KraZy's Avatar
th400 RMVB and replacing the t70 w/ a s400
Old Aug 3, 2007 | 10:43 AM
Phil99vette's Avatar
7 Second Club
Where to start...
Just finished the 25.5 cage
Engine is done @ the machine shop and getting ready to assemble
Probably have 60 days of work to get it done and running.
Phil
