Why Am I Losing Boost - Incon Setup
cablebandit has stated he never had this issue. Could it be I'm getting valve float? I'm running Comp 918's in it now. Could I have so much pressure on the hot side to cause this condition? I'm really scratching my head on this one, I've been chasing this issue for a couple of years now.
Please help!
- Dug
mahhddgtp if you are right, then there's really nothing I can do aside from larger turbos then? Not worth it if that's the case.
You can always de-stroke to smaller cubes...
If the ar is 86 (Look at the castings) it's not the housings. I've seen GT2871R's (What you have) hit 20 psi on bigger motors than you have.
Are you sure the boost controller is set up properly. I ran 17psi with those turbos with a very steady pressure line with the EB2 controller.
427ci
ALL of LPE +400ci builds used GT2871R turbos on the "standard" builds. Their 9.5 at 145mph Vette that ran the plane in MT was a 427 with GT2871R's same as the Incon base....those baby turbos make some great power for their size. My best was 9.9 at 141 at Bristol (+4000ft DA)
Now running GT3582R's.
Took a look at my controller last nite, it is the original Greddy Profec-B. Now here's the interesting part. It of course has the balance ****, and low and hi boost *****. Supposed to tune by putting the balance in the middle and adjusting low/hi to your liking. It you get boost spikes you turn the balance **** clockwise to sharp until it stops. If you get boost hunching ( falling off ) then you turn counter to mild. IF you still have spike issues, there are 4 dip switches on the back giving 4 possible settings. Two are for actuator type, two are for external wastegate type. One of the options for both setups is if you get boost spike you can adjust the dip switch. Mine is flipped for actuator type in overboost situations, so I'm thinking that is why it's falling off on the top end. Hope to do some tests today after the roads dry up.
