APS TT Kit, Setup
Old Oct 1, 2007 | 08:41 PM
  #41
Big Bird WS6's Avatar
will the turbos work with a 455ci?
Old Oct 2, 2007 | 08:38 PM
  #42
farrellt's Avatar
Default 2002 Firehawk
Year Make Model: 2002 Firehawk
Engine-
Block(CI): Forged 403 LS2
Compression: 10.76:1
Oiling: LS6
Crankshaft: Callies Dragonslayer
Connecting Rods: Compstar
Pistons: Diamonds
Cylinder Heads: AFR 205,s Reworked by Tony Mamo with huge low and mid-lift flow increases
Camshaft: Com XER 220/220 581 114 +2
Rocker Arms: Stock (Upgraded pushrods & Valvesprings)
Intake Manifold: Tony Mamo Ported Fast 78 MM
Ignition/Computer: Stock
Exhaust: Corsa Catback with Hooker Y-pipe
Cooling System: Stock & 160 stat
Fuel-
Pump: dual in-tank, Alky control Meth kit
Injectors: Siemens 60lb
Rails: FAST
Drive train/Transmission-
Transmission: Stock T-56
Clutch/Converter: SPEC 3+ with Aluminum Flywheel
Driveshaft: PST
Rear Axle: Moser 12 bolt, 3.73's,
Chassis-
Front Suspension: UMI K-Member, UMI control arms, Hotchkis swaybar, Hotchkis lowering springs with Koni single adjustable
Rear Suspension: UMI LCA's, BMR Panhard rod, SPOHN torque arm, UMI Reloc brackets, Hotchkis springs, Koni single adjustable
Brakes: Baer Eradispeed with Stock Powder coated calipers
SLP subframe connectors and shock tower brace
Performance-
758 RWTQ at 3,800 rpms, 706 RWHP at 5,500 rpms with 9.2 lbs of boost, huge average power...Torque monster
__________________
Old Oct 5, 2007 | 01:28 AM
  #43
peter@aps's Avatar
Not ideal for such a large cube engine though I may have some news on larger turbos for the F body system in early 08.
Thanks,
Peter
Old Oct 6, 2007 | 01:45 AM
  #44
LS7jUnKiE's Avatar
...man there are some nice setups in here!
Old Oct 15, 2007 | 02:41 PM
  #45
T A WS6 M6's Avatar
APS TT Kit Setup
Year Make Model:2000 T/A WS6
Engine-
Block(CI): Stock
Compression: Stock
Oiling: Stock
Crankshaft: Stock
Connecting Rods: Stock
Pistons: Stock
Cylinder Heads: Stock
Camshaft: Stock
Rocker Arms: Stock
Intake Manifold: Stock
Exhaust: rusty ole' slowmaster, until I can afford better
Fuel-
Pump: Racetronix single
Injectors: Precision 42.5#
Rails: Stock
Transmission: T56
Clutch/Converter: I have no idea, but it can't be stock (99K miles and it survived tuning)
Driveshaft: Stock
Rear Axle: Moser 12-bolt
Chassis-
Front Suspension: Mostly stock w/ Bilstein Struts and Hotchkis Sway
Rear Suspension: BMR PHB & LCA, Spohn TA w/ DSL, Bilstein shocks, Hotchkis Sway
Brakes: Stock
Performance-
Horsepower: 481 RWHP
Torque: 513 lb-ft
Had to update now that it's done.
Old Oct 18, 2007 | 07:19 PM
  #46
Need help here guys. please help
[U]APS TT Kit Setup[/U}
Year Make Model: 2002 CETA
Engine-
Block(CI):ls1 346 or ls2 stock cube or LQ9 stock cube.------this is where i need the help. anyone please
Compression: 9.0
Oiling: dry sump
Crankshaft: callies
Connecting Rods: callies
Pistons: Diamon
Cylinder Heads: afr 205 of afr 225 ported by tony m
Camshaft: ????????
Rocker Arms: stock
Intake Manifold: either fast 90 ported by tony m or wilson manifold
Ignition/Computer: stock
Exhaust: custom
Cooling System: stock
Fuel-
Pump: twin intank 255
Injectors: 85
Rails: fast
Transmission: rebuilt t-56
Clutch/Converter: tex
Driveshaft: steel / carbon fiber if money is left
Rear Axle: new moser M9
Chassis-
Front Suspension: umi k-member and a-arms
Rear Suspension: DKT Performance Lca and panhard
Brakes:
Performance-
Boost: 18 lbs
Horsepower: (XXX rwhp) wish i knew
Torque: (XXX rwtq) wish i knew
Old Oct 20, 2007 | 08:01 AM
  #47
T A WS6 M6's Avatar
Well, based on what I've heard about boosted LS2s, specifically one GTOs amazing performance as a daily driver (that can run with liter bikes), I'd say LS2. I think you what to talk to Loboost. If you can't find him here go to ls1gto and look for him.
Old Nov 2, 2007 | 12:55 PM
  #48
Rubberduck's Avatar
Any news Peter about the APS engine?
Old Nov 7, 2007 | 12:12 AM
  #49
peter@aps's Avatar
Guys, Here's a quick power/torque graph from our 346 cube twin turbo F body. These power figures are from our load based dyno and we estimate that the power would be around 10% higher on a dyno jet dyno, around 860 rwhp, enjoy!
Peter
Old Nov 7, 2007 | 02:09 AM
  #50
Hawk 01's Avatar
Default Aps
Peter,
Can you share any specs on the engine and if you are running a standard twin turbo kit or an upgraded version?
JC
Old Nov 7, 2007 | 09:00 AM
  #51
mterveen's Avatar
Default another aps up and running
been up and running for a while, just tuning bit by bit. also setting up for e85 fuel.
APS TT Kit Setup
Year Make Model: 01 SS Camaro
Engine-
Block(CI): 346
Compression: stock
Oiling: stock
Crankshaft: stock
Connecting Rods: stock
Pistons: stock
Cylinder Heads: stock 241
Camshaft: stock
Rocker Arms: stock, updated 918s, tr 7.4 rods
Intake Manifold: stock ls6
Ignition/Computer: HPTuner 2 bar speed density
Exhaust: none at the moment-3in true duals, h pipe
Fuel-
Pump: Racetronix/Lonnies double pumper,converted to return system/AFPR
Injectors: Mototron 63#
Rails: speedinc
Transmission: M6
Clutch/Converter: stock LS6
Driveshaft: stock
Rear Axle: stock
Chassis-
Front Suspension: stock / bmr K member
Rear Suspension: SFC/TA relocation / panhard bar relocation
Brakes: stock
Performance-
Horsepower: (XXX rwhp) no dyno yet
Torque: (XXX rwtq)
converting to E85
Old Nov 7, 2007 | 10:45 AM
  #52
MY99TAWS6's Avatar
Peter that is great numbers but how about some more exact details now.
Is that withthe afr 225 heads think the small chamber or the 72cc size?
Is that the gt7 cam in there still?
What boost is that? Can you give afr and or some timing info. Was that pump gas or meth or what?
Was that fast intake a 78 or 90mm?
Are you going to play with any different cams in the motor like think you originally planned?
What clutch are your currently running since you said other one would not hold the power?
And think you said you are running your twin pump fuel system with the add on rail/line option? Would like to see the afr numbers to see how the fuel system is holding up.
Also looks like power drops off pretty quickly past 6000.Is that due to the cam you are using? The gt7 doesn't make any real power past 6000? Or was there some other thing .Would have liked to see the graph going to 6500 or so.
Old Nov 7, 2007 | 05:45 PM
  #53
peter@aps's Avatar
Originally Posted by Hawk 01
Peter,
JC
JC, I will get the engine combination for you in a few hours time. The twin turbo system is a straight off the shelf APS F body twin turbo system, same twin turbo system as we have sold into the US for the last 3 months.
Thanks,
Peter
Old Nov 7, 2007 | 06:10 PM
  #54
peter@aps's Avatar
Here's a quick run down of the 346 forged engine build,
1) Forged Mahle pistons, comp ratio is 9.2:1 with AFR 225 64 cc chambers.
2) Forged Oliver con rods,
3) stock crank,
4) AFR 225 64 CC cyl heads,
5) 90 mm fast intake manifold,
6) 90 mm throttle body,
7) ARP fasteners,
8) GT 11 cam shaft,
9) APS twin pump fuel system,
10) Meth injection system,
11) Custom Twin plate clutch,
12) 20 PSI boost,
13) AFR 11.1 at peak torque, 12:1 at peak power,
14) Ignition timing 14 - 16 degrees,
Hope that helps,
Peter
Last edited by peter@aps; Nov 12, 2007 at 10:44 PM. Reason: combstion chamber size was incorrect
Old Nov 9, 2007 | 04:33 PM
  #55
MY99TAWS6's Avatar
Excellent Peter on those spec list. Do you have any personal experience on how lopey that gt11 cam is.I think may sell off my gt7 and get the gt11, the gt7 does seem a bit smallish,especially since going a bit bigger than your 346.
Oh couple more questions for you. Fuel pressure you are running and size of injectors you are running.
Old Nov 9, 2007 | 05:29 PM
  #56
JMBLOWNWS6's Avatar
Engine- LS2
Block(CI): 402
Compression: 9:0:1
Oiling:Meling,moroso oil pan
Crankshaft:Callies
Connecting Rods:Callies
Pistons:Wiesco
Cylinder Heads:Trick flow 235's, L19 head studs, Fel pro gaskets
Camshaft: Custom (Cam motion)
Rocker Arms: Yella Terra
Intake Manifold: Vic JR ported and matched by LME
Ignition/Computer:Stock
Exhaust: Lethal performance true duals out the back with borla XR1's and DMH cutouts
Fuel- Nasty Performance Fuel system
Pump: Magnafuel 4303
Injectors:Mototron 60# / 96# versafueler
Rails: Edelbrock
Transmission:4L80 MVB with lock up
Clutch/Converter: Pro Yank 3400 extreme
Driveshaft:ACPT carbon
Rear Axle:moser 9"
Chassis-
Front Suspension:BMR K member,UMI A arm's,QA1's,BMR T arm
Rear Suspension: QA1's,LCA's,BMR panhard relocation kit,BMR panhard
Brakes:
Performance-
Torque: (XXX rwtq)
Old Nov 12, 2007 | 05:42 PM
  #57
peter@aps's Avatar
Excellent Peter on those spec list. Do you have any personal experience on how lopey that gt11 cam is. I think may sell off my gt7 and get the gt11, the gt7 does seem a bit smallish,especially since going a bit bigger than your 346.
The GT 11 cam has a nice lope to it, sounds and performs very nicely imo.
Running 60 lb per hour injectors with around 78 PSI fuel pressure (58 PSI plus boost pressure on the fuel reg).
Peter
Old Dec 1, 2007 | 03:45 PM
  #58
Tom@SpeedInc's Avatar
Default To the top: APS numbers
APS TT Kit Setup
Year Make Model: 2004 GTO
Engine-
Block(CI): 402ci
Compression: 10.3
Oiling: Melling 10296
Crankshaft: Eagle
Connecting Rods: compstar 6.125
Pistons: Diamond 11520
Cylinder Heads: Dart 225
Camshaft: 225/225 .581/.581 113
Rocker Arms: stock
Intake Manifold: FAST 90
Exhaust: Magnaflow
Cooling System:stock
Fuel-
Pump: 2x walbro 255 inline, 2nd pump run by hobbs switch/relay
Injectors:60lbs hr.
Rails:speed inc.
Transmission: M12 t56
Clutch/Converter: RPS Stage 3+
Driveshaft: BMR
Rear Axle: stock GTO 3.46 BMR axles
Chassis-
Rear Suspension: stock
Brakes: stock
Performance-
Horsepower: 635rwhp @ 5800 7psi
Torque: 645rwtq @ 4500rpm
Old Dec 1, 2007 | 04:22 PM
  #59
Country Boy's Avatar
Senior Member
Peter
The graph looks good, but why are you losing 200 ft lbs of TQ in about 1500 RPMs? Are the turbos too small?
Old Dec 1, 2007 | 04:56 PM
  #60
FWIW, 7PSI combined with 402ci
