APS TT Kit, Setup
Old Dec 2, 2007 | 08:44 AM
  #61
Country Boy's Avatar
Senior Member
damn! Thats only 7psi?!
Old Dec 2, 2007 | 05:39 PM
  #62
Rick@HSW's Avatar
awsome numbers Fraser. how long before you up the boost and see what you can get??
Old Dec 2, 2007 | 08:54 PM
  #63
qqwqeqwrqwqtq's Avatar
Yeah Fraser, how long until you sprout a set?
Old Dec 3, 2007 | 06:48 AM
  #64
Rick@HSW's Avatar
Old Dec 3, 2007 | 01:22 PM
  #65
ls1greg's Avatar
APS TT Kit Setup
Year Make Model: '02
Engine-
Block(CI): 348
Compression: ~9.2:1
Oiling: "GM High Volume Oil Pump"
Crankshaft: OEM
Connecting Rods: Manley I-beam 4340
Pistons: Manley -16cc forged Al
Cylinder Heads: LPE CNC'd LS6
Camshaft: LPE GT2-3
Rocker Arms: OEM (918 springs, CompCam's pushrods)
Intake Manifold: OEM
Ignition/Computer: MSD, TR6 / HPTuners RTT
Exhaust: SLP Dual/Dual
Cooling System: OEM
Fuel-
Pump: Racetronix
Injectors: Siemens 63lb/hr (a.k.a. 60s)
Rails: OEM
Drive train/Transmission-
Transmission: A4
Clutch/Converter: Yank 3400
Driveshaft: OEM
Rear Axle: 2.73
Chassis-
Front Suspension: 35mm sway bar, Eibachs, Bilstiens
Rear Suspension: 21mm sway bar, Eibachs, Bilstiens
Brakes: OEM
Performance-
Horsepower: 308 N/A
Torque: 305 N/A
Old Dec 3, 2007 | 09:28 PM
  #66
peter@aps's Avatar
Originally Posted by ls1greg
APS TT Kit Setup
Engine-
Block(CI): 348
Compression: ~9.2:1
Crankshaft: OEM
Camshaft: LPE GT2-3
Cooling System: OEM
Fuel-
Pump: Racetronix
Rails: OEM
Transmission: A4
Driveshaft: OEM
Rear Axle: 2.73
Chassis-
Brakes: OEM
Performance-
Horsepower: 308 N/A
Torque: 305 N/A
When do you expect to be up and running?
Peter
Old Dec 4, 2007 | 01:14 PM
  #67
MY99TAWS6's Avatar
Peter I am thinking going up to gt11 cam from my gt7 that have now.
Also afr heads. Do you have the 8019 afr spring upgrade on their or any other make of springs since that gt11 is 633/644 lift ??
Old Dec 4, 2007 | 05:16 PM
  #68
peter@aps's Avatar
I'm not sure of the valve spring part numbers as the cyl heads came complete from AFR with the valve springs. Tony at AFR may be able to help you with that information.
Peter
Old Dec 11, 2007 | 09:12 AM
  #69
mterveen's Avatar
ta ws6 m6 - did you post a dyno chart? if so can you link me to it? thanks.
