8s with a 347??
Old Aug 27, 2007 | 06:51 PM
TN94Z's Avatar
Default 8s with a 347??
How hard would this be? Keep in mind, I have all suspension and rear is in the works and the fuel system will be taken care of. And the car weighs about 2900lbs. I wanted to go more ci, but it doesn't look like that is going to be an option over the winter. So I am re-working the motor that is in it for forced induction. Would this be easier with gas? I am assuming not. I just don't want to go with gas because it is getting so high around here. 75.00 to fill my 15lb bottle!!! That is going to add up way too fast. Thanks
Old Aug 27, 2007 | 07:32 PM
theblur98ss's Avatar
Harlen did it way back when. I think he was spooling incons pretty high though. Ltlhomer also did it with twin t67's I think. I'd guess $10k-$15k should be able to get it done.
Old Aug 27, 2007 | 07:43 PM
mahhddgtp's Avatar
I think Homer did it with an LT1.
347's in the 8's? Baby stuff..
Old Aug 27, 2007 | 07:45 PM
TN94Z's Avatar
I didn' think it would be that big of a deal. KP is getting very close with a d1sc right?
Old Aug 27, 2007 | 07:55 PM
2QuickZ's's Avatar
Both cars were LS1's. ltlhomer bought Harlan's turbo kit. Harlan's car was definitely a 347. I think ltlhomer's was, too, but I'm not sure. Both of them weighed more than 2900 pounds.
Old Aug 27, 2007 | 08:00 PM
kp's Avatar
kp
10-15K for what
Harlan and LT1Homer both used the exact same twin turbo setup, they also ran pretty large solid roller cams and high RPM. If you have the smaller CID you need more RPM to move more air.
Its more then possible to do obviously, just most opt for the bigger CID as opposed to 8000rpm But the 8000rpm route is probably easier on head gaskets if thats any relief..
Old Aug 27, 2007 | 08:53 PM
y2khawk's Avatar
i was ~3250 at the time
Old Aug 27, 2007 | 08:56 PM
mdhmi's Avatar
That was an LS1/6 block.
You funny boy.
Old Aug 27, 2007 | 09:13 PM
BigBronco's Avatar
nah, few more bucks then that to get it done.
Old Aug 27, 2007 | 09:28 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Harlan went like a 8.29 in 2003 or something, and Sean went I think 8.7 in 2006.
I've got the power to run 8's, we'll see if I can put it all together.
Old Aug 28, 2007 | 07:18 AM
TN94Z's Avatar
Procharger is what I have in mind instead of turbo. But I am not ruling out turbo. I have access to a 408 l92 setup but I was just curious if I could get it done with the 347.
Old Aug 28, 2007 | 08:10 AM
LS1Tech Co-Founder
347, 18-20psi, 3200-3300, good air, and you will run 8's.
Old Aug 28, 2007 | 08:13 AM
kp's Avatar
kp
Yea, lets not forget about getting the car to 60 foot.
If it were that easy everyone would have done it by now..
Old Aug 28, 2007 | 08:14 AM
LS1Tech Co-Founder
Hehe not easy for sure, but he'd end up around those numbers.
Old Aug 28, 2007 | 08:41 AM
kp's Avatar
kp
Its not THAT hard to do really, my junk I threw together in my garage is close and if making an 8 second pass was a priority I would have done it by now. But I wont give up things like power steering/brakes, stock hood, wiring and I hate fixing the thing so I keep it tuned very safe. So I pay the price by being slow.
All depends on your perspective on the whole thing, only reason a I keep a 347 in this car is out of sheer laziness. Its there and it runs fine so I see no need to replace it or try to blow it up just yet, has nothing to do with trying to run x.xx with xxx CID. I highly doubt anyone will ever run as quick as harlan did on a 347 unless NHRA comes up with a comp eliminator combo that would favor a 347 CID, 3250lb FI LS1 setup.
But if you have a nice 347 no reason not to use it and try
Old Aug 28, 2007 | 08:56 AM
LS1Tech Co-Founder
I think Harlan's record will hold for a long time, because you'd either run twins or a light car with an 88 or more likely a 91 to get there. But most folks shooting for low 8's tend to be running more cubes, and there is no class that incentivizes folks to run stockish cubes.
Old Aug 28, 2007 | 09:06 AM
TN94Z's Avatar
The car works pretty well right now as far as suspension goes. Now the MT 275 drag radials is another story. So far my best 60ft was a 1.48 leaving pretty soft around 1800. It has alot left in the 60ft I think. I just hate to go out and spend the money on a bigger ci motor when this one is fine. But saying that out loud does remind me that I would be buying forged internals for it...hmmmm. Anyway, my perspective is this: I want a low 9sec/high 8sec car that is fairly consistent but reliable enough to bracket race. I know the consistency thing has alot of factors but those are my goals.
Old Aug 28, 2007 | 09:13 AM
LS1Tech Co-Founder
I went 1.35 with my old TCT converter/ 3450 raceweight/ September/ 680rwhp/ 18psi leaving off the transbrake. My guess is that if I had had time to mess with that combo more, like the tune, and pulling weight out, it would have went an easy 9.25.
Old Aug 28, 2007 | 09:37 AM
kp's Avatar
kp
Its not that hard to do, I have one sitting here that does just that and is very consistent. I would most likely be better off with a 364/402 but I just dont see spending 6-7K at this point for a couple tenths since I'm pretty bored with it. I would at least go with the 4" bore honestly unless its super low budget.
Old Aug 28, 2007 | 09:51 AM
TN94Z's Avatar
Your car has really been catching my attention and that is how I want my car to perform. Bored? What do you mean? Any thoughts of getting rid of the car or what?
