warped t6 flange from welding
Old Oct 12, 2007 | 07:12 PM
bumpin_records's Avatar
Default warped t6 flange from welding
I was building a nother turbo kit. working on the stainless steel t6 flange well i guess welding the piping to the flange i warped the flange. Do anyone think that if i bolt the exhaust housing to the t6 flange and heat it up as i tightend the bolts and let it cool off it will be back flat?
Old Oct 12, 2007 | 08:01 PM
Turbo LS1 SS's Avatar
not a good idea. put it on a belt sander or get it milled
Old Oct 12, 2007 | 08:05 PM
Phil99vette's Avatar
7 Second Club
Mig or Tig?
Old Oct 12, 2007 | 08:14 PM
shoemike's Avatar
how bad is it warped?
if it`s like "taco" warped just cut it off and get a new one.
Old Oct 12, 2007 | 09:41 PM
Ari G's Avatar
It´s a good idea to Bolt them to scrap heads to keep them from warping badly
allso preheat the flange,then it´s not as likely to warp but after welding i would suggest to mill the flange
Old Oct 13, 2007 | 04:49 AM
stevieturbo's Avatar
Same as above. Get it machined flat.
The only thing you will bolt it to, that might flatten it, is a miracle if you can find one
Old Oct 13, 2007 | 04:53 PM
it was miged. its not warped too bad just twards the ends the center is flat but i dont wanna take any chances of leaks after i install it .lol lol well i will see how much it cost if it cost more than the flange it self i will just make a new one. thanks
Old Oct 13, 2007 | 07:13 PM
well, if you have a lot of patience, and a sharp file, you could file it flat.
Old Oct 13, 2007 | 09:31 PM
RealQuick's Avatar
I have welded ~10 T4 flanges and not one has warped.... they were all mild steel, but it seems like you are using too much heat.
Old Oct 13, 2007 | 09:47 PM
SuperZ's Avatar
or to thin of a flange
Old Oct 13, 2007 | 10:04 PM
99.9percenter's Avatar
Just beat it flat with a hammer. Put some shim under it if your having trouble getting it real flat(so it overbends when you hit it.
Old Oct 14, 2007 | 09:51 AM
RealQuick's Avatar
I have welded 3/8" and 1/2" thick.... hopefully he isnt using anything thinner than 3/8".
Old Oct 15, 2007 | 10:02 AM
It was 3/8 304 stainless steel
Old Oct 15, 2007 | 12:51 PM
lionelc-5's Avatar
GEt it milled, desnt matter how you weled it, it will now have a memory and as it cools it will pull back to its warped shape, unless you realy get it hot. With tig there is alot more heat input into the base metal compared to mig, even though the tig weld is a better weld. You could put it in a press and cold bent it also.
I run a pipe fab shop in Houston and deal with this (on a bit larger scale) all the time.
Old Oct 15, 2007 | 02:51 PM
cablebandit's Avatar
the t-6 flange on my ofi kit was warped from welding..i called Joel and he said it would straighten up when bolted up and not leak....he was correct.....i am using one of those metal gaskets between the turbo/flange
Old Oct 15, 2007 | 05:11 PM
NassyVette's Avatar
I did the same thing the first time I welded up my stainless crossover and flange. I just bought a thicker flange and worked slower with the welder and made a new one.
