Wastegate for a T88
Here we go again. You gave us one piece of information that has no connection with wastegate size. Wonderful.
I'd use dual TiAL 60mm units if I were you. At least we know they won't be too small.
Want real help? Engine size, engine mods, redline RPM, approximate HP on boost, max boost levels to ever be used, etc. Give us something to work with minus "I have this turbo."
Sorry for being so stupid FieroZ34 but I wasnt aware you needed so much info.Its a 408 with Dart 225's fully ported with about 12lbs of boost redline about 6200.Ls6 intake,225/225 581/581 113 cam,1 3\4 full length headers and its a STS kit.
I wouldn't go any smaller than a 46mm just because you'll have boost spikes since something smaller won't be able to bleed enough air out fast enough..
Hey Fiero, seriously what's up with being so condescending?? Didn't you get banned a while ago for being a jerk and throwing your infinite knowledge of POS's around?? You don't have to be an *** about everything... We're here to help and I understand about people needing to give more information but try to be a little more tactful about it..
With a 408 and 12psi you don't need anything monsterous. The big cubes help since you won't bypass as much exhaust as lets say a 346. Anything 50mm-60mm will work fine. Even the Turbosmart 48 will do the job.
You'll have a pretty potent setup. I'd honestly go for a 60mm unit, I know TiAL makes a very nice 60mm. A 46-48mm might be sufficient, but there's only one way to find out, and that way could end in disaster. And if you go too big, it won't hurt anything.
As for where to find one, as always you can't go wrong with a site sponsor, but I urge you to check eBay first. If you find a new, never used, name brand wastegate, you can get a top quality unit for very cheap. I got my TiAL 38mm for about 2/3 of wholesale from someone who bought it, then never needed it. But if there are none on eBay, I'd go with a sponsor.
I disagree. The big cubes will mean even more exhaust volume, and at the relatively low boost levels, he is going to need to bypass quite a bit of exhaust. I'll agree on the wastegate size, but by all means a 50-60mm wastegate isn't small!
I have one Tial 44mm gate on a 381 inch motor and ran it with an 88 and a 91. Low boost wasn't a concern of mine so i put a 14psi spring in it and it would run at 18psi of boost, without the boost controler. Wastegate placement plays a big role in controling boost.
Sorry typed faster then my brain......it is reversed.
