does this look right (pic)
Old Nov 19, 2007 | 11:11 PM
Rickys S/C Z28's Avatar
Default does this look right (pic)
i took off my head unit tonight and took some pics, just wanted to run them by you guys and see if it looks right, this is my first time working on an LS motor, and the first time working with FI so if any thing looks out of place plaes tell me thanks
Ricky
thats the only way i could get it off
Old Nov 19, 2007 | 11:13 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
the flux capacitor in the lower pic looks like it should be replaced.
Old Nov 19, 2007 | 11:22 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
I usually leave the J bracket on the car and take the head unit off the J bracket by removing the allen head bolts. But, yeah, it looks to be mounted correctly if that was your question? You may have to reclock it a bit depending on your intercooler piping... My outlet almost faces straight down, but the piping will dictate the ultimate direction.
Old Nov 19, 2007 | 11:51 PM
yes the J bracket was a bitch to get off with the head unit, but i did not have much of a choice, the allen head bolts look to be messed up? can i replace the allen head bolt with any kind that will fit??
ha ha ha ha come man
Old Nov 20, 2007 | 12:01 AM
kp's Avatar
kp
How did get that standoff loose without taking the head unit off
You can replace the allen bolts but make sure they are the same length.
Old Nov 20, 2007 | 12:06 AM
ok cool man by the way whats the standoff?? is that the long nut looking thing in the bottom pic??? if so i just unscrewed it till it came off?? i hope i did not mess anything up?
Old Nov 20, 2007 | 12:23 AM
kp's Avatar
kp
The bolt behind the blower must not have been very tight. Its a lot easier to take the blower off the bracket first as mentioned
Old Nov 20, 2007 | 12:36 AM
trust me is was hard as a **** to get it off, im going to try to get the J bracket off the head unit eather tonight or in the morning ill take more pics as i go
thanks KP
Old Nov 20, 2007 | 12:43 AM
ALLBOTTLE's Avatar
LS1TECH Sponsor
check the tools/fabrication section.
someone sells a special tool just for the procharger guys, looks pretty cool.
Old Nov 20, 2007 | 01:05 AM
can you post a link to it?? i looked but seen nothing?
Old Nov 20, 2007 | 01:07 AM
ALLBOTTLE's Avatar
LS1TECH Sponsor
here you go
https://ls1tech.com/forums/showthrea...er#post7495127
Old Nov 20, 2007 | 01:35 AM
sweet man thanks!!!!!!
Old Nov 20, 2007 | 02:21 AM
ok cool i got the J bracket off and the allen bolts are good they just looked bad and i did not want to take a chance of messen them up!! but i am learning as i go
now time to clean this bad boy up!!
Old Nov 20, 2007 | 06:32 AM
blown98z28!!'s Avatar
If you replace the socket heads, you need to make sure you get new ones that are the same strength and have the same coating. Any type of socket cap of the same size will not do. Just FYI if the issue ever comes up again.
Old Nov 20, 2007 | 07:01 AM
thanks buddy
Old Nov 20, 2007 | 12:56 PM
kp's Avatar
kp
The stock ones are stainless I believe, wouldnt be a real good idea to use anything that can rust..
Old Nov 20, 2007 | 06:41 PM
great Kp thanks!
Old Nov 21, 2007 | 02:31 AM
Default more pics! any help or all good
Old Nov 21, 2007 | 02:33 AM
not to bad for 2 days work(i think iv had my cherry popped! hahahahah hope to get the heads off tommarrow
