Plug Issue
Old Dec 15, 2007 | 07:34 PM
Kaneman's Avatar
Default Plug Issue
I am currently using TR6 gapped to .025 and about 5000 rpms we are pretty sure the spark is getting blown out. AFR is good and no knock but when it hits 5000 rpms and 18psi boost it jerks like we are loosing spark. Anyone have any solutions? Should I gap closer?
Kane
Old Dec 15, 2007 | 08:33 PM
Kaneman's Avatar
Anyone ever try these?
Zex 82071-8 POWER RACER™ V8 SPARK PLUGS
Kane
Old Dec 15, 2007 | 08:51 PM
HUNTER02SS's Avatar
I would switch to a colder plug with 18lbs. of boost. Try a set of ngk-7317 or equivelant.
Do a search on here for spark plug's and you will find out everything you need to know!
Old Dec 15, 2007 | 09:35 PM
Inspector12's Avatar
TT-TECH Veteran
NGK-BP7EFS pn#3526
Although at 18 psi I wasn't having any issues with the TR6's, but everyone's car is different.
Old Dec 15, 2007 | 09:36 PM
ninetres's Avatar
Does anyone have the link to the chart of ALL NGK plugs and their specs??? I've been searching for like 5 minutes and can't find it!
Old Dec 15, 2007 | 09:38 PM
ninetres's Avatar
FOUND IT!!!
http://www.ngk.com/sparkplug411.asp?...g+Chart&mfid=1
Old Dec 15, 2007 | 09:43 PM
ls1290's Avatar
Dumb Ass Vette Moderator
Why are they TR6's gapped to 0.025"??!?!?! They should be 0.034".
Keith
Old Dec 15, 2007 | 09:55 PM
DuronClocker's Avatar
Old Dec 15, 2007 | 11:09 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Your plugs aren't the problem--yet. Using a plug that is too hot will cause detonation later, but not spark blow-out. I'm guessing you have spring related valve control issues, ie "valve float". I'm betting some other problem would fubar your motor before you blow out the spark on a tr6 gapped at .025. With all of that being said, after you do find the real problem, the 6's may be too hot for 18psi.
Old Dec 15, 2007 | 11:55 PM
Kaneman's Avatar
We have always had issues with them gapped like that. All the forced induction guys I know go from .024-.027.
I guess the vlaves could be floating but I have new crane dual springs in the car.
Kane
Keith
Old Dec 16, 2007 | 12:04 AM
Kaneman's Avatar
Forgot to add one thing when I take the car to the higher rpms not in boost everything is fine. So the issue starts at around 5000rpms if I run it up there with no boost the problem is not there.
Kane
Old Dec 16, 2007 | 01:53 AM
TT-TECH Veteran
Well without boost or not under a load isn't the same I am sure you know that though. I am with these guys there is another issue. What cam are you running? And Crane springs whats the numbers 832??? the added presure on the back side of the valve can effect it with a combination that is on the edge of being too much for the springs etc...
Old Dec 16, 2007 | 06:10 AM
stevieturbo's Avatar
On LS1's ?? or other motors ?
LS1's have very powerful coils, so there is no need to drop the gap down that small. The stock coils are well tried and tested, to crazy power levels. So unless you actually have some faulty coils....it is highly unlikely you do not have enough spark power.
Old Dec 16, 2007 | 07:47 AM
Slowhawk's Avatar
LS1Tech Sponsor
I agree that it is probly not spark.I would look into the springs.You have to account the 18lbs of boost pressurizing the back of the valve.
Old Dec 16, 2007 | 11:12 AM
Zombie's Avatar
I run my TR6's or Autolite 103's with a .025 gap. I haven't had spark blow out issues until the boost reached 24psi (could have floated the valves too, I turned it back down after that).
Post the graph
Old Dec 16, 2007 | 12:32 PM
Kaneman's Avatar
Here is the dyno graph.
http://members.***.net/kane-forum/Dyno121507.htm
Kane
Old Dec 16, 2007 | 12:58 PM
Kaneman's Avatar
Let me give you guys some specs on the motor:
408
Custom JE Pistons
Eagle crank
Callies rods
Stock 6.0 heads
LS7 Cadillac lifters
Crane 832 dual springs
7400 pushrods
Yellow Terra Rockers
Now that the motor is broke in I may want to check the pushrod lengths again. At the time of the build the geometry was set.
Kane
Old Dec 16, 2007 | 01:02 PM
qqwqeqwrqwqtq's Avatar
First, you should check the ground strap of the plug immediately after a pull to determine heat range, which will likely be a 7 or 8 ngk at 18+psi boost. Also increase coil dwell time to 7ms by peak boost.
I do agree that it's likely insufficient valvesprings. Boost at the back of the intake valve is not a problem but backpressure on the back of the exhaust valve is. We usually try for a minimum 165psi seat pressure but sometimes go as high as 200psi on the seat in our higher horsepower hyd roller builds. We use stock rocker arms as well.
Old Dec 17, 2007 | 02:38 PM
Kaneman's Avatar
So what is the easiest way to make totally sure it is actually valve springs? I had 918's in this car with the 408. We recently had to pull the motor and put new pistons in it because the clearences were to loose and it was causing piston slap in all cylinders. While the motor was out we upgraded to the Crane Duals and I put the LS7 lifter in. I did not have this issue with the Comp-R lifter and the 918 spring.
Here is a question we had a 7400 pushrod with a Comp-R lifter which is way to much preload. We now have a 7400 pushrod with LS7 lifters. The geometry was right at build time but may be off now. Will the valves float if the pushrods are to short?
I will get the covers off and do some testing to make sure everything is right up top.
Kane
Old Dec 17, 2007 | 03:03 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
It's easy to swap in some NGK TR8's, I have them in both cars, and the Camaro runs just fine with them NA, though I put them in for the spray.
I ran Crane 832's a while back, they were okay but at one point I went to some Comps because it seemed like the Cranes were floating after I put in a more aggressive camshaft. I went from a 230/236 to a 236/246, maybe Jim remembers. I think we went to Comp 977's at that point, though I now run a set of ET springs with my AllPro heads.
