6.0l 370 with MPT70 .96a/r ?
hey guys what do you think about this turbo for my 9.1 compression 370 with a master power t70 t4 with a .96a/r turbine hot side in my daily driver will it work fine for up to 550-600hp thats all i want not much so let me know what you all think?
we all 550rwhp wont keep you happy that long. im guessing you have this turbo already and thats why you want to used. a 76mm on Kyles T/A was being choked i believe. and thas why he stepped it up to an 88mm
You might want to consider the tc76 that Jose over at Forced Inductions sells. It has pretty good reviews and is suppose to offer quick spool, reliability and good power for an affordable price. Basically a cheaper turbo that isn't junk. Definitely can't go wrong with the T76GTS either. Just isn't cheap....
the t76 is rated up to 1100 hp im not planning on not even 700hp just the most close to 600 range its because i use to had the MPT70 turbo on my 5.3 and i blew the engine so right now im building a 6.0 30 over so im just planning on leaving my mpt70 and see how it works so i wont even get close to 600 hp with this turbo or even 550hp so what do you all think like i say i dont want 700-1100 hp im fine with over 500 hp with my 6.0l !!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
The power rating of the turbo has nothing to do with why the turbo doesnt fit the combo very well. The problem is that you have a 370 cubic inch engine and a turbo with a small exhaust side. When you start to push the turbo to make more boost/power there will be alot of backpressure. There is only one way to find out if that t70 will make the power you want it to on that motor.
well if it does causes alot of back pressure will it mest up my engine or it will just make some hp at some level and thats it but i can still try it out right with out breakin' my engine ? or what? and thanks for the help guys.
So will it work for around 580hp not some hard core hp im happy around 580 the the most so will my Master Power T70 .96 a/r get me there or even close. So what do you think I know a T76 would be great but the t76 is rated up to 1000 hp and thats to much for me. This is my daily driver with a little turbo so can i give it a try anyways and i wont mess up my engine with the T70 ,this turbo is rated up to 650hp - 800hp i think??????
what dose the 2/1 backpressure ratio means is it the .96a/r T4 flange or what. And how can i mesure the back presure on my engine is there some kind of calculator to mesure the back pressure.
Just like you do on the manifold, you need to tap the hot side and run a line/gauge that can stand up to the high exhaust temps.
The t70 is a little small for the 370, its small for my 357. I haven't measured my backpressure yet but my last set of gaskets says its high - Popped the gasket in 3 different places at once.
Sick of the MP bashing over hear on tech - Just because somebody USED to sell them and advertise the hell out of them, and now since they don't sell them everybody hates it. Its a good entry level turbo. Don't turn it into the ebay split compressor legend, which was false too.
