6.0 and ls1 241 heads whats the diffrence on them ?
Old Feb 27, 2008 | 01:14 PM
mike06tork's Avatar
Default 6.0 and ls1 241 heads whats the diffrence on them ?
heyv guys if i put some 241 ls1 heads on my 6.0l 370 engine so i can pick the compression up to about 9.1 will it work good because im building my engine with some probe -16 dish pistons and if i use my 6.0 heads in will end at about 8.4-8.6 compression and i dont knopw if this will be good for my daily driver and i only plan on using no more than 15# of boost at the track and with some meth so i also have a set of 241 so can i use them ? what do you all think and whats the diffrent on the 6.0 and ls1 heads ? thanks
Old Feb 27, 2008 | 03:42 PM
mike06tork's Avatar
come on guys i really need your all help..... on this
Old Feb 27, 2008 | 03:52 PM
fast01's Avatar
Stick with the 6.0l heads, they have a much better port design. The ports on the 317's and 035's are the same as the LS6 heads (243's) only the chambers are bigger. That's just my opinion.
Old Feb 27, 2008 | 04:15 PM
Johny GTO's Avatar
longest run-on sentence..... ever.
Old Feb 27, 2008 | 04:28 PM
fast01's Avatar
That's funny!
Old Feb 27, 2008 | 08:35 PM
Mr.MartyStone's Avatar
Turbo or sc?
Old Feb 27, 2008 | 09:50 PM
mike06tork's Avatar
For a turbocharged engine. its on my daily driver im not planning on hard core horse power just some around 580 hp ill be happy so what do you all think?
Old Feb 27, 2008 | 11:47 PM
fast01's Avatar
If you're not looking for every ounce of power the 241's will be fine. They don't flow as well in stock form as the 317's, but on a FI engine, cylinder head flow won't make as much of a difference as it would NA.
Old Feb 28, 2008 | 01:08 AM
mike06tork's Avatar
will low compression 8.5 will be tha same as 9.1 compression with a turbo in a daily driver? what will be best ?
Old Feb 28, 2008 | 01:31 AM
fast01's Avatar
I don't think the .5 will make that much difference, but then again I'm a FI newbie myself and have never driven a FI car with compression that low. Maybe someone with a bit more experience will chime in.
Old Feb 28, 2008 | 02:35 AM
mike06tork's Avatar
anybody else let me know asap.
Old Feb 28, 2008 | 02:59 AM
gold98Z28's Avatar
have the 317's milled to achieve the compression you want, they are better heads, i had mine milled .045 to bump the compression up on my lq4
Old Feb 28, 2008 | 03:06 AM
mike06tork's Avatar
hey how much -cc did it drop by getting them milled .045 on the heads ?
Old Feb 28, 2008 | 03:22 AM
gold98Z28's Avatar
i didnt cc them but doing the math, about .007 is approximatly 1cc so i shaved off about 6.4 cc so. the average cc of the heads being 71-72 put me about 65.5 or so
