Throttle feel from turbo guys...?
How do you guys feel about it?
Do you get used to it?
Or nothing you even worry about?
I drove my 3.8 S/C without the belt because the supercharger was low on oil once, and it was a complete dog in terms of power and throttle response.
If you think an LS1 F-bodt tuned for F/I has less than stellar throttle response and off-boost driveability, try driving a 4 cylinder turbo import like a WRX or Evo. Now those are gutless engines.
until you rev up and get some boost created
for some its just preference i guess too. If you've always liked ford your whole life, you will never buy a chevy no matter what. Nitrous guys usually never go to boost because thats all they know and love
As said you are usually cutting compression ratio and running less timing,richer afr. So off boost these things can hurt a bit. But as also said you sacrifice a bit to get the massive area under the curves that turbo systems are capable of. But supers and NA builds can give quicker response for sure. Just have to pick your power adder. None of them are perfect.
Nitrous ,especially small shots can also be used with super or turbo to good effect.
The main thing is to mod the car properly depending on if its a street car or strip or combo. A strip car can have a massive slow to spool turbo , a street car should have a quicker spooling smaller turbo so you get more useable power band. A power band from 5000 to 7000 is not as good on the street as a power band from 3000 to 6500.
Was this trans am you drove a m6 or an auto? If auto was it stalled? What was the CR? There are a lot of different stuff that can make a modded car feel sluggish. Your fquick page shows that you are fairly stock. IMO, It is not really good to compare your car to this guys car
My turbo seems to have a fairly small AR (street setup), and spool time is very short. You do not even notice it. I am still on a stalled auto, so part throttle is a bit sluggish (compared to stock). My CR is around stock, so it is not bad at all. However, during my own situation, my car gained throttle response, and gained more part throttle power. It was not a lot, but it was enough to notice.
So, to answer your question... It is all in the setup.
The turbo car I drove is a M6 and so is mine. So yes I was comparing it and I realized I was comparing apples to oranges.
The car I drove belongs to FENIX999 who replied in post 13 and 14.
