Boost starting at high RPM
Old Mar 7, 2008 | 08:31 PM
71chevellels1's Avatar
Default Boost starting at high RPM
Im new with this whole FI world so bear with me please.
The motor is a ls1, it has a 76mm Turbo, hks bov, tial 44. It only has a mail order tune with a turbo base tune for now till i get it driveable. My tack is not hooked up yet but when its idleing it has around 20 vac when i give it gas it dosent go into boost until just right before the rev limiter. I know by not having the tach working i cant get a good reading of what rpm im at but basically i dont see boost till about 1k short of rev limiter. This is a DIY turbo kit so it may be an error that ive caused. Also i have my bov on a vac T thats connected to the line that goes from the side of the WG to the compressor housing and considering its a HKS it should be loud and it dosent make any sound but this is because the Bov should work when the motor comes from boost back to vac right? Does anyone know what my problems could be? THanks!
Old Mar 7, 2008 | 08:46 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Your late boost could be exhaust leaks, incorrect wastegate reference, oversize turbine housing A/R, etc. However, the BOV reference definitely needs to come from the intake manifold in order to work properly.
Old Mar 7, 2008 | 08:49 PM
Yea i figured i would start by checking for leaks, thats what im going to do in the morning. I think the WG is refrenced correctly strait from the turbo. The turbine housing is .81. I had the bov hooked up to a T in in the brake booster line and it did the same thing.
Old Mar 8, 2008 | 10:39 AM
Old Geezer's Avatar
If UR revving it in neutral, U will likely not produce boost.. Try loading against the brakes..That will produce high EGT, and ex gas pressure.
Old Mar 8, 2008 | 11:18 AM
2002ws-6's Avatar
yeah what old geezer said. No load = no boost. try it on the street and get in to it little by little, It's best to have a wideband o2 to make sure your not leaning out
Old Mar 8, 2008 | 12:27 PM
ok, well ill stop trying to mess with it then untill its driveable.
Old Mar 8, 2008 | 12:30 PM
kidcamaro98's Avatar
you wont see any boost in neutral. Turbo needs load from the motor/tranny/rear end and this isnt reachable in neutral...revving it, isnt proving anything....-20 vac. is 100% normal tho....thats what It should be. When cold and warming up, my car idles at -19...once warm, its at -21.
Also, dont run your BOV off any other vac. lines. Run it straight from a vac. line from you intake manifold. Same goes for the wastegate.
Old Mar 8, 2008 | 03:49 PM
topend's Avatar
turbos dont care about your drivetrain.they care about exhaust flow, which is controlled by your right foot.
u could build boost in neutral . all u need is a 2 step rev limiter.
Old Mar 8, 2008 | 04:55 PM
jerrad's Avatar
A two step builds heat to create more exhaust temp which leads to spooling the turbo. Old geezer is 100% right.
Old Mar 8, 2008 | 07:13 PM
really?? then explain to me why you cant build boost in neutral and it builds in gear?? Also, why does switching rrear end gears affect spool time?? The load you get from your gears and when your in gear affects your exhaust flow, hence putting a load on the turbo making it spool IN gear.
Old Mar 10, 2008 | 08:22 PM
topend's Avatar
Ask anyone with a manual transmission and a turbo how they spool the turbo at the starting line.check out the begining of this video.
http://www.youtube.com/watch?v=2wMVfSrxfdM
most ppl switch rearend gears because they ran out of gear or lugged the motor at the finish line.Your turbo will begin to spool in wot at X rpm in any gear.It takes time for the turbo to spin up to the designated boost.for example say your turbo takes 3 seconds to go from 1 psi to 15 psi.IT will take 3 seconds in any gear. 3 seconds will eat more of the time in 1st gear than it would in 3rd gear.
Old Mar 10, 2008 | 08:54 PM
gametech's Avatar
Umm, what? Have you ever even driven a car with a turbo? Your statements about load in different gears is only true IF you have enough traction to load the motor and IF you don't run out of gear before you even get spooled. And boosting with a 2-step off the line has very little to do with load on the motor, and a lot to do with fuel burning in the exhaust pipes while leaving the throttle wide open to allow air in to mix with it.
Old Mar 10, 2008 | 09:48 PM
ls1_chevelle's Avatar
dude we seriously need pics
Old Mar 10, 2008 | 11:53 PM
Ok then explain to me why a STandard car spools the turbo again and again during every shift and a auto spools it once...because during the shift on a standard your taking the LOAD away from the motor...with a auto, once you mat it, the load is always there KEEPING the turbo spooled.....your "theory" didnt prove a damn thing....
Im not sure how many cars you have seen build boost in neutral revving...but I can only get 1psi If I bounce off the rev limiter in neutral....compared to when Im in gear, and power breaking....I can build boost but my tires start spinning before I see anything more then 3psi.
You ever been in a turbo car when the tires are spinning so much the boost starts to drop? Why is this? because spinning tires is taking away load from the motor....
you can argue with me all you want. Im right. Research it.
Old Mar 11, 2008 | 12:27 AM
SS4Matt's Avatar
the small turbo ar should have no problem spooling, that's why i bought it in the first place with my old M6 setup. i wanted turbo spool NOW. if you are just revving it in neutral, it might make a pound or so tops. try just driving the car down the street or something if it's driveable and i bet that turbo will come up really hard
Old Mar 11, 2008 | 02:48 AM
Dam thanks for the input, i thought i had a bad boost leak or something, its my first turbo car and i built the whole turbo system my self so i thought it was an error in my work. So then when you hit about 1# in neutral does your bov go off?
Old Mar 11, 2008 | 07:16 AM
TNTramair's Avatar
it may build just enough to hear the Valve upon releasing the gas yes.
if ya get a chance, post some pics for us to see. Ls1 Chevelles are sweet!!
Old Mar 11, 2008 | 07:23 AM
geeteego's Avatar
Boost way late...is it a rear-mount by chance?
Old Mar 11, 2008 | 01:30 PM
Ya ill have to take some pics,
No its a front mount.
Old Mar 12, 2008 | 07:29 PM
topend's Avatar
.................. because when u shift u take your foot off the gas(except for lencos,liberty trans). part throtte = less exhaust.
check out this turbo viper.
http://www.youtube.com/watch?v=9IOpu...eature=related
