Methanol Injection Before Maf??
Old Apr 5, 2008 | 04:00 PM
Jon614z28's Avatar
Default Methanol Injection Before Maf??
Hey, guys, i started running my car with the 5.3 turbo swap, noticed that after the methanol had been on for a few seconds in boost i throw a maf code p102, the nozzle is before the sensor and i was wondering of it could be throwing it off, what do you think????
Old Apr 5, 2008 | 05:24 PM
vandal0-0's Avatar
I have both of my nozzles after the maf.The methanol spraying threw the maf is most likely your problem.
Old Apr 5, 2008 | 06:27 PM
AIS's Avatar
AIS
Relocate your nozzles after the mass air.
Old Apr 5, 2008 | 06:30 PM
Jon614z28's Avatar
Default meth
Thanks guys, i unplugged meth and drove it, much smoother under boost also no codes being thrown, Thanks again
Old Apr 7, 2008 | 09:15 AM
AIS's Avatar
AIS
Sure thing. Just place the nozzles after the maf and you'll be fine.
Old Feb 20, 2013 | 11:55 PM
JoshuaGrooms83's Avatar
i kniow its old, but just wondering why the water/meth would cause an issue withthe MAF?
Old Feb 21, 2013 | 12:06 AM
k_cash1432's Avatar
Think about it...Your MAF is used to measure air flow, not water/meth flowing over the sensors. Ever over oiled a K&N filter and had it get oil on the maf? Same concept with the meth...
Old Feb 21, 2013 | 12:50 AM
i suppose i can see it form that way. yeah i had a dirty MAF from when I switched over to a 85mm truck maf and i thought i made a mistake. then i descreened it and found that it was caked in dirt and grim. once cleaned it was running perfect.
Old Feb 21, 2013 | 07:18 PM
k_cash1432's Avatar
Yep now your on the right track!
Old Feb 21, 2013 | 07:33 PM
yep, understood... after the MAF it is then.
Old Feb 22, 2013 | 04:12 AM
Jontall's Avatar
http://www.alcoholinjectionsystems.c...icle_info.html
Old Feb 22, 2013 | 10:13 AM
guess im gonna hve to run the IAT sensor separate from the MAF then, damn. i really wanted to run it this way but guess ill have to use the external sensor.
Old Sep 17, 2018 | 09:06 PM
ascastil's Avatar
Resurrected! Instead of making new thread, can I mount meth nozzle before the maf if going to sd tune and the maf isn't used? I have an 04 so the iat is part of the maf sensor.
Old Sep 18, 2018 | 01:46 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Yes. As long as you are SD, it won't matter.
