LSX is ready to be dropped in tomorrow (PICS!)
Old 09-03-2008, 07:34 AM
  #421
TURBO383WS6's Avatar
if it's your neutral switch and reverse switch that are mixed up, wouldn't the reverse lights be on while in park??? that one should be easy to check without switching wires.
Old 09-03-2008, 07:58 AM
  #422
rufretic's Avatar
I was wondering about that myself. I'm not sure how the switches work though, if it's just momentary or switched on or off. If the nuetral safety switch is switched on to dissable the start up, then it would be in the on possition through all the gears but in the off position while in park but then if it needs to be off to start the car, if they are reversed the car should start anyway because the reverse lights would also be in the off possition in park. It should be easy to figure out though, I just have to go through the gears and make sure the reverse lights come on in reverse only, if they don't then I have them wrong. Will the the reverse lights even come on with the car off though? I guess if I have the key turned, they should have power so they should still come on when I put it in reverse right? Man too many changes at once to track down a problem I need to get back out there and start narrowing down these possibilities, I can't wait to get home from work today, I'm staying out there until I figure this out.
Old 09-03-2008, 08:13 AM
  #423
rufretic's Avatar
Originally Posted by Rickys S/C Z28
good luck man when i built my motor it took me 3 dau to find out why it would not start! come to found out i had a bad ground and a alt wire wrong
Wow, now the alt comes into play too. I didn't hook up that brown looking cable that was related to the alternator because when I was reading up on reconnecting my wiring harness it was said that that was a useless ground and it can be ditched. Looks like now I have to figure out what that was hooked up to and put it back on Anyone know the one I'm talking about? It has a hole for a bolt on each end, about 2' long and looks like a gold/brown shoe lace(flat). I just opened up a whole **** load of possible problems Looks like I got some work to do.
Old 09-03-2008, 09:37 AM
  #424
Pat-Man's Avatar
Isn't that the grounding strap? (shoelace wire)
Old 09-03-2008, 09:40 AM
  #425
rufretic's Avatar
Yeah, it was a ground of some sort for sure, the wiring write-up I read about hooking everything back up stated that it was useless though and it could be deleted?
Old 09-03-2008, 09:53 AM
  #426
BTLBABY's Avatar
I know this doesn't have anything to do with your wireing issue but, I was wondering about your hood brackets. Is that something you made or does someone offer those for our cars?
-Cole
Old 09-03-2008, 10:09 AM
  #427
rufretic's Avatar
-Cole
I made them, it's a pain in the ***.
Old 09-03-2008, 10:11 AM
  #428
rufretic's Avatar
Here is how I figured out a lot of my wiring:
https://ls1tech.com/forums/showthrea...und+alternator
The #7 & #9 is the grounding strap I'm talking about. Is it needed and where does it hook up?
Old 09-03-2008, 01:59 PM
  #429
8 sec potential, 12 sec slip
ChevyChad's Avatar
was your car an auto before or a M6? Just wondering cuz if it was an M6 it could be the clutch switch... but then if it had that, you wouldnt have a neutral safety switch, so ignore this post if you were an A4 to begin with...
Old 09-03-2008, 02:46 PM
  #430
rufretic's Avatar
It was an a4.
Almost time to go home and figure this out.
Old 09-03-2008, 08:34 PM
  #431
rufretic's Avatar
Alright, got some things worked out tonight but have a new problem. The reason my starter wasn't working was because I had the switches on the shifter reversed. Good call kgaligher and TURBO383WS6, yes the reverse lights were on in park, guess I never thought to even look back there. So I switched them and now they both work how they should. Thanks guys. Now back to the starter, now I'm getting power to it and it's definitely doing something but it ain't crankin the motor. Now when I go to start it, it makes a loud clicking sound and all the lights and gauges flash with the clicks. It's not like a dead battery click, much louder and quicker. I don't think it's engaging with the flex plate but I'm not sure, it just doesn't feel right and it definitely doesn't sound right. It's not turning the engine over, that much I can tell for sure. I guess I have to have someone crank while I'm under there and see what it's doing. Anyone ever experience anything like this?
Old 09-03-2008, 08:56 PM
  #432
TS6
TS6's Avatar
That really sounds like a dead battery man. Either that or the starter needs shimmed.
Old 09-03-2008, 09:04 PM
  #433
Restricted User
98Z28CobraKiller's Avatar
Make sure you dont have something arcing
Old 09-03-2008, 09:10 PM
  #434
Dark Shadow's Avatar
charge the battery.
Old 09-03-2008, 09:56 PM
  #435
rufretic's Avatar
It's not the same as a dead battery, I know what that sounds like. This is much faster and louder.
Old 09-03-2008, 10:06 PM
  #436
ChevyChad's Avatar
ya, id guess you forgot to tighten a bolt somewhere that either goes to a ground or a major power wire like the one that goes to the starter or the battery. If its not a dead battery, id say its an arc like 98Z28CobraKiller mentioned
Old 09-03-2008, 10:57 PM
  #437
Silver_TransAm's Avatar
Yeah I am thinking it is an arc or a lose connection somewhere, or even a pinched or broken wire that might have got crushed at some point.
Good luck and nice build!!
Old 09-04-2008, 04:36 AM
  #438
1dirtyZ's Avatar
make sure you have the block grounded properly!! i learned the hard way on my stang
Old 09-04-2008, 06:58 AM
  #439
rufretic's Avatar
Ok guys, thanks for all the help so far. How do I go about finding an arch? Also, whats the best way to ground the block? Should I just hook up a cable from the block to the frame?
Old 09-04-2008, 07:02 AM
  #440
Rickys S/C Z28's Avatar
thats what i did but i used the flat looking wire that you were talking about
Quick Reply: LSX is ready to be dropped in tomorrow (PICS!)
