LSX is ready to be dropped in tomorrow (PICS!)
so try swapping the whole coil tray from side to side and see if that works.
did you take the coils off the tray by and chance?
It will be easier to understand with a vid but just to give you an idea. It doesn't sound very good, like not even close to starting. It turns the engine over with out much sound at all usually the first time. Then if I try again it will do the same thing but then make a couple loud pops.
what about "stupid" stuff? like:
-spark plug wires on tight
-spark plugs not fouled
-injectors harness clips on all the way
-fuel is good
-all grounds in place
-cam gear/crank gear lined up dot-to-dot
-timing chain tight
-valves open/close properly, no collapsed lifters or bent pushrods
-no vacuum leaks; brake booster, MAP sensor, TB flange, intake connections, etc...
i know you've gone over and over the motor, but it never hurts to do it 2 or 3 more times, maybe you missed something. no matter hom much you look, it can always be something small.
...i mentioned spark plugs above, have you pulled a couple (not just one) to see what they look like?
I finished a head swap on GTO today at work outside and went to drive it in to get it on the lift to reconect the exhaust and forgot I had the o2 disconnected . It just popped like you described . Might be that not really sure where your at
1. all sensors except cam sensor are reused from old engine.
(what sensors will the car not even start up with?)
main one I'm conserned with is crankshaft sensor
2. injectors are from old engine (getting pressure at the rails)
3. new tr10 spark plugs (getting some spark but not sure how much)
4. new push rods but stock length (could wrong length cause this?)
5. anything else that would cause the car to not start at all (only a couple pops) but
still have spark and the engine turning over.
I bet it's something easy I'm just overlooking. I finished a head swap on GTO today at work outside and went to drive it in to get it on the lift to reconect the exhaust and forgot I had the o2 disconnected . It just popped like you described . Might be that not really sure where your at
