LSX is ready to be dropped in tomorrow (PICS!)
Let me know I can send you my PCM to see if that will at least start and then you can send it back to me
i dunno man, it sounds to me like (from that video) there is either:
-too much fuel
-not enough fuel (injector issues)
-too much/not enough timing
-some electrical issue; MAP sensor, crank sensor <--most likely
a buddy of mine had a crank sensor go bad in his S10, it did the same thing, more or less, what your car is doing. but then again, if it isn't throwing a code, it probably isn't that...
Didyou swap the crank sensor? It could be the cam sensor too.
If the plugs are soked you need to pull them all and cleand them ,just wipe them with a rag. You may have just flooded it when you had the connectors backwards .
why isnt the blower spinning in the vidio . Should it be ,I am not sure ,but I would think if it was attached to the crank it would spin
-too much fuel
The cam sensor is new and the crank I just didn't change yet because I thought it would show in the scan. I might try a new map sensor since that's the code I'm getting.
The blower is not spinning because I have not put the belt on yet, trying to work the problem out first.
Anyway, I'm assuming that since your on an SD tune that you had to swap MAP sensors. Did you put in a 3bar? I only ask that because I know a 3bar takes a different connector (red) and that would mean you had to transfer wires from one connector to the next... Are you absolutely sure you put the wires in the correct places on the connector?
I think I have a 3bar MAP pinout if you need it, just pm me...
But IMHO, it sounds like your spark events are off. Actually, it sounds just like a carb'd car w/ old school dizzy installed 180* off. You can hear on each attempt at starting that it tries to fire, then on the last one there is enough residual fuel in the cylinders for the off timing spark to cause a backfire.
Not sure how the LS stuff works hardware wise, but you not getting spark at the correct time. I would almost bet my car on it. Try the crank sensor, if it doesn't work, clean it real good and return it. If that doesnt do the trick, could something be installed backward with the coil packs?
Thats my opinion based on what I've seen with all the old school stuff I've done. I've seen people install opti's wrong and get similar results to what your getting. On LT1's the optispark provides the pcm with cam and crank signals, so if its off its f*cked.
