LSX is ready to be dropped in tomorrow (PICS!)
FWIW, I've never seen a pushrod that was 'close' cause low compression numbers. It'll just cause an undesireable wear pattern.
As far as low compression numbers, knowing that the cylinders have been washed, just put some oil in the cylinders. You have not fucked the engine yet, the cylinders are just dry. Put some a little oil in there and re check the compression.
The same thing happens when a motor sits for a long time. If the cylinders are dry you will not get compression readings.
But thats a niice setup you have, looking forward to videos
And im norwegian so there might be some bad language
How do I oil the cylinders and how much? After I check the pushrod length I need, retorque the rocker arms and get some oil in the cylinders hopefully it will build some compression. That's tomorrows project.
Today I decided to get away from the problems/frustration and work on something else that will get me back to a more possitive attitude. It worked, I finished my cog set-up and I'm pretty impressed with it. Belt slip is a thing of the past:
I need to get a nice set of 6 bolt heads anyway but I wanted to at least get it up and running this year. I don't have the money for new heads yet. Dan
After you put oil in the cylinders (i'd prob. use a straight 30wt dino oil), unplug the injectors to be sure that you dont squirt any fuel in and start turning the motor over by the starter while holding the throttle wide open... Watch the gauge after a few revolutions and you should start seeing pressure build.
If not, its time for a leakdown test. Which you can do poor man style by adapting your compressor line to the line that comes with the compression gauge (most have the same quick connect).
Poor man's leakdown test Bring a cylinder to TDC, then fill the cylinder with about 10-15psi of regulated air pressure and listen for where it's leaking out. You will hear some gettng by the ring gap though the oil fill cap. A little there is normal. You dont want to hear it hissing out the intake or exhaust when both valves are closed on that cylinder. That means you either have hanging valves or bad seats. You should be able to tell this just by the volume of air coming out though.
BTW, the cog setup looks absolutely beautiful! Good job man!
One other thing you mentioned got me thinking about something completely off topic but very important. You mentioned cranking it over until the oil comes out the lifter or pushrod. At this point, I'm not getting any oil pressure? I thought that was normal though because it's just not spinning fast enough or for a long enough period of time to actually get the gauge to register any pressure. Just by letting the starter crank it over for how many seconds should I start to build oil pressure?
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
. ive never set valve lash on a ls1 but on a old small block if you over tighten the rockers you will get the same thing alot of popping and no compression. backfires through the intake. just my .02
