LSX is ready to be dropped in tomorrow (PICS!)
If you do not repeat all the above steps for each pushrod, your likely to have some lifter bleed down.
My valve train is excellent. I have dual springs that are good for .7 lift and have the highest seat pressure out of all the ones I've researched because I was worried about the valves floating with the high boost. The set came with everything to be installed with them. They are made for a huge cam so they should be giving me the advertised specs and have the right height, no coil bind and good open and closed presures. No I didn't check them because I don't have the tools or know how to do so. I tried to put together the parts needed to make the project work as a whole. The only thing I messed up on is not getting the right length pushrods but they were close enough the car should have ran. The only thing that I have proven to be giving me problems are these fucked up used 317 heads. They where not part of my original plan but I had to try something because I don't have $3000 for heads right now and won't for a while. The 317 should have worked fine for getting it running but I got screwed by some *** hole that sold me fucked up heads. Maybe they are even milled and that's why the ptv issue. I don't understand the ptv problem but I did clay one piston before I installed the heads, it just so happens it was the one that barely got touched. It had clearance when turning it over by hand so I really don't understand how they hit now. It doesn't matter anyway, they did so now I have to do what I have to do to make things work. I have to figure out why some pistons got hit more than others too, maybe the mill on the heads was off too. If they were milled that would be why the pushrods are too long also. Really the heads could solve all my problems if I run into a little good luck instead of bad.
I'll keep you guy's updated with my progress.
I found something while taking it apart that I don't think is good. Please don't rip on me for this, I'm still learning. I didn't fill the oil pump with oil before I installed it. I thought about it after wards but I thought it would just suck the oil in. It's still bone dry. I would have thought it would have oil in it now from turning it over. Now I'm kind of glad I'm doing it again so I can take my time and do a little more research and make sure everything is right. Am I supposed to do something with the oiling system with a new engine? Was it just because my pump was dry that I wasn't getting any oil? I don't really understand how the oiling system works. I need to get a better understanding of it before I put everything back together because I want to be sure it's all good and I don't have to rip it down again because of no oil pressure.
I'm going to do a bunch of research on my own now but if anyone has some good info on the subject, please feel free to share.
