LSX is ready to be dropped in tomorrow (PICS!)
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
I think it's just a priming issue. I don't like how the pick-up sit's in the pump so I'm going to add a bolt to the other side to make sure it is sealing well. I'm also going to fill the pump and try what Z06psi said. After researching a little, it seems no oil pressure is pretty common and it just takes a good seal and some oil in the system to get it to prime. This time around, I'll make sure I have oil pressure before I put it all back together.
I intalled it with +8 advance! This is why it's best to take your time and double check things. I almost installed the new cam wrong again but decided to look everything over even though I could clearly see it was dot to dot. It's unlikely that this would happen, I have no idea how the top of the 8 got rubbed off but man am I glad I caught it this time around. That should fix most of my issues and the new 317s should fix the compression problem. I still would of had compression issues even if the cam was in correctly because I tested it without the pushrods in and still had leaking from the valves. At least this cam mistake helped me to find a couple other issues to fix while I redo everything. Should be just a matter of putting everything back together now
Lets try not to burn down the car this time
lol. I know a lot of people think I should but I wanted to do this with a big cam, now that I know it had nothing to do with the size of the cam, I'm using it. Anyone want to buy a nice, brand new, FI cam? Thanks for all the suport guys. Hopefully now that I've got the problem figured out it should be smooth sailing getting it back together. Today I fixed the chain, oiled the pump, double checked the o-ring, got the cover back on, got the crank pulley back on and swapped all my valve train stuff over to the new heads. Next up is cleaning up the pistons and bolting on the new heads and yes, I'm going to clay the pistons just to be sure I have plenty of clearance.
He never ran it, now I never ran it so it's still new. I worked out a trade so I'll hook you up with a deal if you want it. PM me if your interested.
lolGood luck with this monster
