LSX is ready to be dropped in tomorrow (PICS!)
The other thing I was thinking is it may not be getting enough air because there is no hole in the tb and the iac sensor is a remote mount so the only air it's getting is at the back of the intake where I have the remote iac tapped into. Most people don't know what that is because most tb's have them built in but it basically is what controls how much air goes past the tb at idle. I had to mount mine in a different spot so I have an air line comming off the intake pipe going to the remote mount block that has the iac sensor in it. Then an air line goes from there to the back of the intake. I couldn't find anyone on here that has one like this so I hope I installed it correctly. The only thing that makes this not a good possibility of being the problem is that opening the throttle actually seems to kill it quicker? It's got to be the map sensor, I'm going to try that first.
Also, what would the TPS have to do with this issue? My throttle is slightly cracked open because the throttle cable is just a touch too tight. I need to adjust it by the pedal just a little bit, I just thought that would make it idle a little higher but if the TPS will cause a problem because it's sensing the throttle is cracked open a little, that could be a possibility as well.
Sorry to see you had that clearance issue. The trials and tribulations are what makes the power all worth while ! Perhaps its time to get that baby down to a shop that has a dyno so you can see if she is running lean or rich.
. I'm not going to be able to do that until the spring so for now I just want it to run so I can at least pull it out of the garage and clean up the mess I made lol. The Best V8 Stories One Small Block at Time
The fuel soak that the plugs is bad news, that can wash cylinders down if you're not careful.
If you can adjust the regulator, try turning the fuel pressure down a little too, make sure you're not flooding it out somehow, anything is possible. Get that fuel pressure down to 45 and see if the car will start and idle there, that and a warmer plug will tell you if it's too rich or not.
As for the fuel system, I don't know what you have on the car for a pump and whatnot, but I'd have at least one aeromotive eliminator pump on there, or 2 a1000's, something like that, with a -10 feed line and a -6 or -8 return with a good regulator, and I'd run at least 110 octane fuel in it right away I wouldn't even bother with pump gas that's totally out of the question at this point.
You've come a long way with this build and it is impressive for a first attempt that is for sure, don't give up now you're not that far away from having it up and running
First pass at the track and you're gonna be getting seriously sent home, to get a TON of safety stuff upgraded, that I am sure of once it's working right.
And yes, I probably won't get to make many passes before getting kicked out and needing a bunch of saftey stuff. I'll be taking it easy at first anyway just test it out and just do some shake downs before I even get close to trying to make a full pass. I want the safety stuff on it anyway, it's just so expensive
not sure this will help, but nothing worth having comes easy.
and learning only comes through pain...it won't come any other way.
wisdom comes with age,...and lastly, if i may quote Confusious...
"man who fart in church, sit in pue"!
you'll work out the kinks to find a new set of kinks...
this is the world of boys and thier toys...
you gotta love it!
keep your head up my man...your right there.
