LSX is ready to be dropped in tomorrow (PICS!)
Shoot me a PM w/your shipping address.....I'll make a donation to the build.
A donation would be awesome! You know you'll get some good advertising from me here
Now if only I could get a few more donations I might actually get this thing running in the next couple weeks lol.
I'll pm you.
1. Head gasket bolt holes don't line up
2. Beck intake hits valley cover and doesn't sit flush
3. Can't remember where a couple electrical things go and can't find the cam sensor plug to hook in my new ls2 conversion harness.
The head gasket thing isn't huge because the only holes that don't line up are the extra lsx block holes and I'm not using 6 bolt heads yet but I'm still going to try and get them to send me a new set for when I do the swap because $200 is a lot for gaskets, they should be right.
I'll take the beck intake off next time I'm working on it and remove the valley cover so I can grind down the edge on both sides. Hopefulley that will fix that issue. Not sure if you can tell in this pick but I don't want to risk it with the amount of boost I'll be throwing at this thing so I'm going to redo the intake regardless to make sure I have a good seal.
Then for the wiring issues. Fist off I can't find where the stock ls1 cam sensor plug is. I have the ls2 conversion wiring harness hooked up to the new knock senso location and cam sensor location but I'm not sure which plug was for the original cam sensor. Is it one of these?
I also can't remember what all went on the alt and where to mount all those stupid grounds behind the intake. If I remember right, they just bolt to the head but I can't remember if all three go on one bolt.
Over all, I did pretty good starting to hook everything back up. Here's where I'm at.
yes it is one of those 2 plugs (the other is the crank sensor on the side of the block)
and those 3 grounds originally have 2 bolts and go on the back of the head but u can put all 3 on 1 it wont hurt anything.
good luck man looks good
I think I figured out that those sensors are the map and the cam position sensor but you got me thinking with the crank sensor now because I havn't hooked that up yet either. Here are the only plugs I have left to hook up other than the transmission stuff and I still have to hook up the crank sensor and starter. Is this black plug in the pic for the crank sensor? It looks just the same as the other plugs that I used for the cam sensor and map. And where does that big long plastic thing go? I can't remember. Thanks a ton for your help.
ya the sides are refered to looking at the motor from the backside.
Actually, I don't remember my moroso pan having a spot to put that oil level sensor, I'm going to have to go check it out.
It is confusing though if not used to it.
Billet pulley is on the way!
