LSX is ready to be dropped in tomorrow (PICS!)
Old Jun 15, 2008 | 11:43 AM
  #141
rufretic's Avatar
Originally Posted by TLewis4095
Any time an application refers to right or left it is related to you sitting in the car (left fender, right fender, left frnt tire, rt frnt tire, etc.)
It is confusing though if not used to it.
Billet pulley is on the way!
Sweet, I can't wait to see it.
Old Jun 15, 2008 | 11:45 AM
  #142
rufretic's Avatar
I'm getting good at this ****! Head gaskets fixed, they lined right up after I swapped them. I wish I would have tried that before I installed everything the first time lol. That was much faster than I thought though. Did the head swap in less than 2 hours, I'm pretty proud of myself, lol.
Old Jun 15, 2008 | 04:33 PM
  #143
1dirtyZ's Avatar
you know your getting good at it when you remove both heads between clases
Old Jun 15, 2008 | 04:34 PM
  #144
07 Z71's Avatar
10 Second Truck Club
should be fun to watch
Old Jun 15, 2008 | 06:05 PM
  #145
helicoil's Avatar
This is great! Wish you the best of luck. Subscribing.
Old Jun 15, 2008 | 06:22 PM
  #146
SeanT/A's Avatar
Very nice build you got.
Old Jun 15, 2008 | 10:11 PM
  #147
rufretic's Avatar
Thanks for the comps guys.
This week is going to get exciting. Once I grind the valley cover down, I'll reinstall the beck and hook back up all the electrical. Then it's time to bust open the F2 box and start working on a bracket design. I'm going to do it in ply wood first(thanks to a word of advise from a member here) so I don't waste my $200 peice of aluminum. Then I'll draw it out on my sheet of aluminum and bring it to the shop to have it machined. I'll keep you all updated with the process as I make it. This is the really cool part where I actually get to start designing my own system. Feel free to post ideas as I start posting pics of my progress. I hope it works!
Old Jun 16, 2008 | 02:07 AM
  #148
1dirtyZ's Avatar
using plywood is the smartest idea i ever heard !!! now that is a smart member
Old Jun 16, 2008 | 10:33 AM
  #149
sevanseriesta's Avatar
also agree that is a smart decision on the plywood.....Kudos to the one that gave this member that Idea.
Old Jun 16, 2008 | 10:23 PM
  #150
rufretic's Avatar
Ran into a couple fitment issues with the beck today. I had to grind the valley cover and then remove the intake again to grind one of the cross bars on the beck.
Now I have it on for good hopefully. Everything is hooked back up and I'm ready to start making my F2 bracket.
Old Jun 19, 2008 | 05:06 AM
  #151
1dirtyZ's Avatar
any updates?
Old Jun 19, 2008 | 07:01 AM
  #152
rufretic's Avatar
Not really, waiting on pay day lol. I did get everything on the engine together and all the wiring hooked back up. I picked up a piece of plywood to start making the bracket but havn't had the time to start fitting it yet. I'll most likely get the bracket template done this weekend.
Old Jun 19, 2008 | 07:54 AM
  #153
rufretic's Avatar
Anyone know the procedure for installing an arp crank bolt? It came with no dirrections and I can't find any info on thier site. Torque specs? Lock tight or lube? Right now I'm thinking 250ft/lbs and lock tight but want to be sure.
Old Jun 19, 2008 | 09:54 AM
  #154
ls2 bait's Avatar
good question. i was going to get one with the frequency in which i have been going thru gm bolts lately.
Old Jun 19, 2008 | 10:16 AM
  #155
Websy21's Avatar
Try searching as I have one and searched a shitload but decided to keep it for when I put my 370 in and get a gm bolt for my stock engine. I beleive that the majority said torque it down to 220-240 and call it a day.
Old Jun 19, 2008 | 07:32 PM
  #156
1dirtyZ's Avatar
loctite is your friend
Old Jun 20, 2008 | 02:08 AM
  #157
nvmy2000ss's Avatar
250 is what I torque them to. I dont use locktite.
Old Jun 20, 2008 | 02:37 AM
  #158
dochall22's Avatar
Wait a minute - someone is giving you free stuff? WoW - I need to build a new motor maybe i'll get some free toys!!! Awesome build! cant wait to see some vid's
Old Jun 20, 2008 | 06:47 AM
  #159
rufretic's Avatar
So everyone is just guessing on the ARP crank bolt specs? I can't believe ARP doesn't have specs on this crank bolt, I thought thier stuff was very torque specific to get the right amount of clamping force?
Old Jun 20, 2008 | 08:54 AM
  #160
Websy21's Avatar
If you search you will find the info you want. I found several threads that a couple different members have phoned ARP themselves and asked them. I just can't remember 100%. I do rememeber it being b/w 220-240 or so. They also talked about appying some kind of arp 'special juice' to the threads as well. Search is your friend. I can tell you that I used mine to fully seat my pulley and never even hit 200lb and it was a bitch to back it off.
