LSX is ready to be dropped in tomorrow (PICS!)
Old Jun 20, 2008 | 09:45 AM
  #161
rufretic's Avatar
Originally Posted by Websy21
If you search you will find the info you want. I found several threads that a couple different members have phoned ARP themselves and asked them. I just can't remember 100%. I do rememeber it being b/w 220-240 or so. They also talked about appying some kind of arp 'special juice' to the threads as well. Search is your friend. I can tell you that I used mine to fully seat my pulley and never even hit 200lb and it was a bitch to back it off.
I've been searching like crazy, the problem is everyone has different answers. I think I may finally have it. torque the stock bolt to 240ft/lb, remove stock bolt, using arp lube on the head, washer and threads, install new arp crank bolt to 190ft/lbs. That is suposedly ARPs instructions but I havn't actually talked to them. I'll probably just have to call them to make sure. If I use the lube, 190ft/lbs is alot because there won't be as much friction. I don't like the idea of the lube though because it makes me think the bolt would come off easier as well. I may just use the lube on the head, washer and half the threads and then put lock tight on the end of the bolt for a little reasurance.
Old Jun 20, 2008 | 09:59 AM
  #162
rufretic's Avatar
Just got off the phone with arp tech line. 235ft/lbs with arp lube, no lock tight. Out of everything I've read on here, none of them were right, lol. There it is for the next person searching. They just have to read through 9 pages of my build to find it, lol.
The weird thing is, when I asked about lock tight, he said lube or lock tight? That doesn't make sence to me but he said lube before I asked so that's what I'll use.
Now the question is, if I called again and got someone else would they tell me the same thing? LOL, oh well, that's what I'm going with.
Old Jun 21, 2008 | 11:30 AM
  #163
rufretic's Avatar
And I thought it was going to be easy, lol
Well the bracket design is coming along pretty good. I think it's going to be possible but I will not be able to run a air filter. I'll have to rig up a screen type filter that will just go over the inlet. I guess that's pretty common for race aplications anyway, it sure won't be restricted. Anyway, the biggest problem is the pulleys don't line up right now. I'm going to have to move the radiator up another 2-3 inches
Here's a couple progress pics. Remember, when I get the final bracket design it will be layed out nicely on the aluminum and machined to look good, not all hacked up, lol, like this wood prototype.
Old Jun 21, 2008 | 11:33 AM
  #164
Websy21's Avatar
I think you need a bigger s/c that thing is freakin small, LOL
Old Jun 21, 2008 | 11:41 AM
  #165
427's Avatar
427
Need to run another one on the drivers side!! Looks like fun.
Kurt
Old Jun 21, 2008 | 11:55 AM
  #166
Websy21's Avatar
Ya thats about what I figured, I was sure they said about 240 with the lube.
Old Jun 21, 2008 | 12:00 PM
  #167
ChevyChad's Avatar
8 sec potential, 12 sec slip
why not mount the F2 down low? seems like there would be more room down there to move it forward a bit more? Maybe not... I dunno.
Old Jun 21, 2008 | 03:14 PM
  #168
rufretic's Avatar
It might have a touch more room down low but I want this thing to be seen. That's why I chose to mount it up there, it's polished and oh so pretty. Since I'm making my own bracket anyway, I figure I'm going to mount it where I want it.
Old Jun 21, 2008 | 03:21 PM
  #169
rufretic's Avatar
Holy ****! This is really going to work! It's mounted where it's staying now. I have room for about a 2" belt, it clears the hood and I'm in the process of moving the radiator up a couple more inches. I'm so excited I got it to fit, I don't even know what else to say. Here is how it will be mounted, of course I will be adding more cross bars to make sure it is solid.
Old Jun 21, 2008 | 04:01 PM
  #170
platinum1's Avatar
great work!
Old Jun 21, 2008 | 05:29 PM
  #171
JL ws-6's Avatar
Race your car!
ou may, want to look into a different radiator, one that is thicker but a good bit narrower, so that you can offset it to the right. That may help your cause a whole bunch.
I'd get thet thing mounted up where you need it, maybe even foreward a touch more so you can run a full 3 inch wide belt on it, and once you have it mounted where it will work and have your charge piping done, get a radiator made afterwards. PITA I know, but you probably can have a radiator made that is a good bit thicker and much more narrow that will do the cooling job and fit in the space you have left when you are done.
That's good that the inlet lines up with the hood too like that.
Old Jun 21, 2008 | 05:34 PM
  #172
JL ws-6's Avatar
Race your car!
Also, if you use a 1/4 inch thick alum piece, I would attach it to the block, the motor plate, and attach it to the chassis. Weld a good thick beefy tab to the frame on the passenger's side,maybe even a U shaped one that goes around the whole drame rail, support the back wide with some triangles and attach the big thick alum plate that holds the blower to that.
I'd try to run a support piece underneath it to the front too to the radiator support area if there's anything strong enough there.
Get that thing on lockdown, it will only make things less painful down the road.
Awesome buildup, I love where you're going with this. Everyone is so "turbo" these days, it's nice to see someone doing something a little different. Even if it doesn't outrun all the turbo setups, it's gonna be unique
Old Jun 21, 2008 | 06:26 PM
  #173
1dirtyZ's Avatar
SAWEEEEEEEEEEEEEEEEEEET!!!! i can't belive the hood actually fits !
thanks for giving me an idea for how to mount my blower on the stang
Old Jun 22, 2008 | 12:41 AM
  #174
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
What hood is that? I'm suprised it fits too. That one shot from the side makes it look like it doesn't have a chance.
Old Jun 22, 2008 | 11:01 AM
  #175
stevensLS1's Avatar
been following the build the whole time man! glad everything is working out for you even though you've ran into some problems! car should be a complete monster!! good luck!!
Old Jun 22, 2008 | 12:39 PM
  #176
ChevyChad's Avatar
Looks awesome where it is now! I only have one question- whats to stop the belt from 'walking' out towards the front and then getting caught up on the bracket? That would suck!
Old Jun 22, 2008 | 12:55 PM
  #177
Rickys S/C Z28's Avatar
looks grear so far man!!
Old Jun 22, 2008 | 04:27 PM
  #178
1dirtyZ's Avatar
to answer thae belt question : its the tensioner pulley that will have tall side walls .
Old Jun 22, 2008 | 05:38 PM
  #179
rufretic's Avatar
Exactly!
Hey man, thanks for the link to that tensioner site, lot's of options there. I should be able to use one but all the pulleys look so narrow. If I could just find the right size pulley, I think I can actually rig up my own style tensioner simular to the one that comes on the 8 rib bracket. That exact pulley but wider, like 2" wide would work perfect.
Old Jun 22, 2008 | 05:45 PM
  #180
rufretic's Avatar
The template is just about finished. I still need a tensioner, a hole for the other radiator hose and I may take a little more material out, like slots in the blank areas. But the main foundation is down and fit's. I'm going to need to mount the tensioner right next to the water pump which will serve 3 purposes. One is to tension the belt obviously, two is to keep the belt in line with a large lip so the belt doesn't shift around and three to move the belt over enough to clear the water pump. Here's where I'm at so far.
