Thinking about a Boosted 5.3L IRoc
Ive got an LM7 In my iroc, and im looking to thump the power output in the ***.
Id like to do the 5.3L Turbo because, ive already got the engine (with only 5k miles on it), Not many people have done it, and id like to see what i can get out of the little motor.
That being said, im not sure if i should modify the motor any before i boost it.
Here's what im thinking:
241 Casting heads - Larger Valves & Larger chambers to lower compression
02+ LS6 Cam - Allow a little more air in
Already have an LS6 intake on it and a ported TB. Id rather put 243 casting heads on if its a good idea to lower the compression, but the 243 casting heads are expensive and will eat into my budget.
Im thinking a single Turbonetics T-76 or MPT70 Turbo, i know the 70 is cheaper, but im not sure if it will accomplish my 600rwhp goal. Im planning on using modified truck manifolds (Need to spin collector a bit & clearance the side of flange to clear the thirdgen subframe rails)
Ive fabricated a custom bumper bar to leave me lots of space upfront, would run a single Front mount intercooler.
All input greatly apreciated.
Thanks
I would opt. for a TC unit over the mp unit any day of the week. You should have no trouble making your goal either way though. The 5.3l is a bad little motor, I have been tuning a cam only 5.3l today with 13psi via a MP122, and it runs awesome.
Ill do some more research on the cam, and pick one out that will work well. Valve springs, i can change, no biggie.
Was thinking the .96 MPT70 Turbo cause its $625 new, so its a decent price, while the T-76 Turbonetics sell for about $800 - $1000 used.
I may opt for a MPT70 then run that for a season, and see how much i can get out of it before i upgrade to something larger.
I figure the 5.3L Block can handle a good HP number, so it would be fun to see how much HP i can get out of it with just a single turbo & the stock rotating assembly.
Im not sure what Wastegate or BOV im going to use yet, still determining that.
Im thinking around 12 - 15psi for the track, and run it at around 5psi on the street.
Sheldon
warren
warren
The N/A Limit is about 500hp, but FI brings in different forces so a FI Limit is much higher.
There was a guy last year who made 772rwhp with a stock '70s 150k mile truck shortblock
Thanks
Thanks, Mike S
