What will max out a D1-SC?
Old Jun 12, 2008 | 08:48 AM
'Trust''s Avatar
Default What will max out a D1-SC?
I'm curious what it takes to max out a D1-SC, and what specifically will max it out? For example, is it simply that the head-unit won't flow anymore CFM? What would it take to max one out before needing to go to F1-A or bigger? Max PSI on a D1-SC etc.? I'd appreciate any input. Thanks!
Old Jun 12, 2008 | 10:16 AM
TS6's Avatar
TS6
"Maxing it out" refers to using pullies that allow the unit to spin to its highest RPM (as recommended by ATI). At that point its giving all its got.
Max PSI is dependent on your motor as boost is simply a measure of restriction. What makes 10 psi on a stock motor might make 6 psi on better motor.
Old Jun 12, 2008 | 12:18 PM
BLNLS1/RX7's Avatar
Pully size.
Old Jun 12, 2008 | 01:45 PM
'Trust''s Avatar
They are telling me 62000 RPM is the limit of the D1-SC but couldn't tell me much more. I assume dampener size falls into affect as well.
Old Jun 12, 2008 | 01:51 PM
DanWS6's Avatar
Yup. Someone posted an excel worksheet that makes this really easy to figure out. You put in the blower/dampner sizes and it tells you what RPM the blower is at depending on the engine rpm. I'll see if I can find the link..
Old Jun 12, 2008 | 01:53 PM
DanWS6's Avatar
https://ls1tech.com/forums/showpost....91&postcount=4
Old Jun 12, 2008 | 02:07 PM
'Trust''s Avatar
Freakin' awesome! Thanks!
Old Jun 12, 2008 | 06:16 PM
EPP's Avatar
EPP
We got 16 psi out of a D-1SC on a 402 with AFR 225 heads, we were surprised and we made 757 rwhp on my Mustang Chassis Dyno. You can check it out here. http://www.exoticperformanceplus.com...Car.php?car=42
What makes 16 psi here in Indiana may only make 10 psi up in Denver. There are a lot of variables involved. Bob
Old Jun 13, 2008 | 08:12 AM
ls1290's Avatar
Dumb Ass Vette Moderator
Up here we do make less boost than sea level, but it is normally not that much of a difference. At lower boost levels, the difference is not too bad. If a setup is making 7 psi at seal level, here at 5800' most people see between 5 to 6. Setups making 14 to 15 psi, will see between 10 to 11 psi here. The thin air really sucks, but everyone is affected so it levels out everything
Keith
Old Jun 13, 2008 | 08:42 AM
No Juice's Avatar
Bob what pulleys were used on this one?
Blower speed?
Old Jun 13, 2008 | 09:05 AM
'Trust''s Avatar
Great build Bob, similar to mine, he has 6 more cubes and a FMIC. Thanks for the link!
Blower speed?
Ditto, ditto.
