need more boost
Old Jul 15, 2008 | 09:00 AM
learningcurve's Avatar
Default need more boost
I have put a vortech supercharger on my 2002 pickup 6.0L, around 6.5 psi and I would like to push around 10 psi, what needs done to the engine to handle this, the engine is stock with dual exhaust.
Old Jul 15, 2008 | 09:18 AM
ls1290's Avatar
Dumb Ass Vette Moderator
I would add a methonal injection kit and get a nice safe conservative tune. Running that much more boost is going to cause more stress on the stock block and internals and they are going to ware out and fail sooner rather than later. The methanol and tune will help things a bit.
Keith
Old Jul 15, 2008 | 09:21 AM
I am willing to replace internal parts, I just don't know what parts I need to replace to handle it.
Old Jul 15, 2008 | 09:30 AM
ss1's Avatar
ss1
Which blower do you have on your truck?
Old Jul 15, 2008 | 11:31 AM
Model# D-213-19 Centrifical supercharger
Old Jul 15, 2008 | 12:04 PM
BadgeZ28's Avatar
Forged pistons that have a dished top to reduce compression, and good rod bolts will get you by.
Old Jul 15, 2008 | 12:18 PM
wound't that take the purpose out of pushing more air to it.
Old Jul 15, 2008 | 12:21 PM
ls1290's Avatar
No. Lowering the compression level will reduce the risk of detonation.
Keith
Old Jul 15, 2008 | 12:25 PM
so a forged kit, good valve kit with dished pistons should work.
Old Jul 15, 2008 | 12:32 PM
ls1290's Avatar
Unless you can do the labor yourself, installing a forged assembly( crank, rods, pistons, etc ) into a existing block is going to cost more than buying a build forged short block.
Keith
Old Jul 15, 2008 | 01:41 PM
yes I could do it myself I would just have to tell them what I am doing because I don't know the numbers game to an engine. I did install the supercharger it just took me an extra 5 hours.
Old Jul 15, 2008 | 02:26 PM
ss1's Avatar
ss1
Ok, the kit for your truck comes with a Vortech V2 SQ SC-Trim blower. It's rated for 1000cfm and ~680fwhp.
At a minimum, new rods & pistons would be the way to start. These other guys have already given some good advice. it may be cheaper to buy a new shortblock and swap over everything from your current engine, unless you want to buy parts and do everything yourself.
Check out this thread below. A brand new 6.0 shortblock, CNC machined, balanced, with high quality parts and assembled for $3000.
https://ls1tech.com/forums/sponsor-sales-specials/947165-weber-racing-summer-engine-sale-also-ptc-converters-transmissions.html
