Oil in downpipe....Heerrreee weee gooo..
Notes: about 2000 miles on turbo, running a scavenge pump, journal type bearing turbo
thanks
Im just wondering what the hell could cause this out of nowhere???
Good luck.
QUOTE=30th t/a;9744595]Not even tuned yet and I got **** happening. Long story short, I start the car up and start driving. Sitting at a stop sign and I notice a **** pile of smoke. I pull into the shop thats suppose to install my exhaust & gears tomorrow. We get the car up on the lift and theres oil everywhere including inside the driver side down pipe.The passenger side looks perfect. I take it a turbo seal went to ****??? What would cause this? I havent even taking the new motor over 2500rpm. Could I have something hooked up wrong? I can I avoid this from happening again.
thanks[/QUOTE]
here is a picture of how my return line does go "uphill" to the fitting coming out of the timing cover. Should I be concerned of how the oil has to travel up into the timing cover?
Also, should I install a restrictor before I just remove the turbo and send it out to get rebuilt??
You haven't taken the new motor over 2500 rpm? How in the world do you expect the rings to seat?? I've taken my car out twice on the new motor/setup and have all of 15 miles on it and its seen idle to 4000 at least a half a dozen times on 2 drives. Varying engine RPM helps the rings to bite the cylinder walls and become better 'seated'. Something to consider...
also, I can see oil dripping out of the turbine side, after I redo my lines, should I have the turbos cleaned out?
