2 Step and Auto
Old Aug 15, 2008 | 07:09 PM
gangbang malloy's Avatar
Default 2 Step and Auto
i am trying to run an aps kit on my auto car and was wondering if i could use a 2 step with the auto? ive have been told that a 2 step is only for manuals is this true?
Old Aug 15, 2008 | 07:38 PM
Derek @ EDO's Avatar
False, there are many guys running 2 steps with autos.
Do a quick search and you will see others' results using them.
Old Aug 15, 2008 | 08:12 PM
so with a 2 step just hold the gas and brake all the way down and it holds the revs at lets say 4k then just let off the brake?
Old Aug 15, 2008 | 08:17 PM
Well, there is more to it than just that.
It cuts spark randomly and limits RPM's
Many 2 steps have an activation or trigger source, activation will depend on which schematic you follow.
You can wire the 2step to a brake switch or even a brake light wire for an activation source. You would want to install a toggle switch inline to prevent the 2step from activating every time the brakes are applied.
If you have the 2 step set at 4k RPM and a brake switch then yes even with the pedal to the floor your engine will only rev to 4k. Once the brake is released the normal spark within the ignition system will takeover and off you go!
Old Aug 15, 2008 | 08:40 PM
what other ways to people hook up 2 steps other than the brake?
Old Aug 15, 2008 | 09:31 PM
quicksilverado's Avatar
The 2-step has one wire to a ground source with a momentary switch inline. Another wire to a 12 volt source at the brakes. You stand on the brake pedal hit the momentary switch and it will engage the 2-step. Floor the gas pedal and the rpms will stop where you have the 2-step set and every other cylinder will fire and then alternate to the other 4 cylinders. When you let off the brakes the 2-step will disengage and all cylinders will fire.
Old Aug 15, 2008 | 09:36 PM
T brake button, Clutch switch, push button (momentary switch)
Old Aug 15, 2008 | 09:43 PM
blu byu EH's Avatar
where can you get one!!!!!!!!!!
Old Aug 15, 2008 | 10:11 PM
Lingenfelter sells them.
Old Aug 15, 2008 | 10:49 PM
code4's Avatar
I have the Lingenfelter on my auto car. I wired it to the trans brake. I like it becuase I can get boost without hardly any stress on my converter/trans.
Old Aug 16, 2008 | 12:35 AM
calongo_SS's Avatar
Is anybody able to actually use one without a t-brake? I'm considering trying it, but I think it will just push through the brakes as soon as it starts building boost.
Old Aug 16, 2008 | 01:59 AM
tomz28's Avatar
i have a m6 car im waiting to put it on i will let you guys know how it works
Old Aug 16, 2008 | 02:02 AM
SpaZMaN's Avatar
Yeah you can. Like other people said, wire it to a trigger source(IE: brake light, momentary button, ect.).
Old Aug 16, 2008 | 07:44 AM
I have one I use on the truck. It takes about 2 seconds to build 5 psi.
Old Aug 16, 2008 | 11:16 PM
would the 2 step work at at low rpms building boost?
if not then i would have to stall it as well.
Old Aug 17, 2008 | 07:54 AM
Rickys S/C Z28's Avatar
so a 2 step kinda acts like a trans brake if im reading this right??
Old Aug 17, 2008 | 11:38 AM
Nothing like a transbrake. You will still need a larger stall to see significant boost
Old Aug 17, 2008 | 11:48 AM
99BlownSS's Avatar
Hey guys can u explain what a 2 step is?????????
Old Aug 17, 2008 | 12:44 PM
code4's Avatar
It's an adjustable rev limiter. Unlike the factory rev limiter it cuts spark to alternating cylinders. This causes a rich condition in the cylinders that sends unburnt fuel into the headers/manifolds where it ignites & causes the turbo to spool.
Old Aug 17, 2008 | 07:16 PM
calongo_SS's Avatar
quicksilverado,
do you have problems pushing through the brakes at the line when boost starts building? Seems like that would be a problem without a trans brake.
