106mm or 91mm
Old Sep 25, 2008 | 03:31 PM
DomesticAbuse's Avatar
Default 106mm or 91mm
I'm stuck between a rock and a hard place. I found two good deals, one on an air research 91mm turbo and the other on a g-trim precision 106mm turbo.
This is the plan:
Car: 1996 chevrolet caprice
Engine: texas speed Iron 408 short block between 9:1-9.5:1 CR
232/240 EPP cam 115LSA
stage II ported L92 heads
L76 intake manifold
90mm TB
Transmission: Outlaw transmissions 4L80E rated at 1,000 HP and somewhere around a 3000 stall with 3:73 gears.
I don't even know what I want for overall power but I guess what ever it ends up being, it will be a surprise. I was thinking atleast 700rwhp. The question is, do I go with the 91mm or the 106mm? I've heard of people running 101 and 106's with 400ci+ LS motors but I want to know if I will be able to make it spool. The car is going to be on the street a good deal so I don't mind if it takes the turbo a little while longer to get up to boost that way I'm not making reciculous power in the lower RPM's. The plan was to push somewhere around 15PSI give or take. Please any opinions would be great. The sooner the better, I'm getting anxious.
Old Sep 25, 2008 | 03:38 PM
DrTurbo's Avatar
LS1TECH Sponsor
Wow for that kind of build up a full frame 91 would do the job. 106 is WAY overkill.
Old Sep 25, 2008 | 05:02 PM
88GT&69ss's Avatar
Yeah i would stay with a 91 or maybe smaller!
Old Sep 25, 2008 | 05:18 PM
daniel6718's Avatar
700 hp you could get with a single 88...easily...
Old Sep 25, 2008 | 05:24 PM
Shawn @ VA Speed's Avatar
I would run an 88,that will easily make the power you want
Old Sep 25, 2008 | 05:34 PM
Frost's Avatar
Originally Posted by DomesticAbuse
That's a sweet looking project!
Old Sep 25, 2008 | 06:46 PM
abbaskhan's Avatar
91 and it would leave plenty on the table
Old Sep 25, 2008 | 09:08 PM
firehawk123's Avatar
Go For FI98X Its Going To Make What You Need . Thats What Am GOING TO have Right Now On My Car . With 408 Ci Hope To See Low 8's .
Old Sep 25, 2008 | 09:26 PM
Fast_94_Z's Avatar
91mm. im only putting a 101 with my big block chevy.
Old Sep 26, 2008 | 12:10 AM
Alright guys well I appreciate the feedback. 91mm it is. I was kinda leaning towards it anyway being that it will save me about $500. I'll post more updates on the build at a later time.
Old Sep 26, 2008 | 10:34 AM
383lt1impala's Avatar
looks like its gonna be a good build. i would go with an 88. im probably going to go with a single 106 im going to try to hit 1400rwhp on c16. but if i were u go with a 400 an 80e with that much power and weight im sure it wont last like a 400.
Old Sep 26, 2008 | 11:49 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I have a PT 106mm for sale, PM me if anyone is interested.
Old Sep 26, 2008 | 03:18 PM
See I thought about doing the th400 but I really do enjoy having overdrive being that this is going to be street driven. I think the 4L80E should be able to hold up for the occasional run at the strip. Does anyone have any guesses as to what the most power this combo could make? I'm figuring somewhere around 475hp before turbo.
Old Sep 27, 2008 | 01:10 AM
calongo_SS's Avatar
You should be able to make over 1000 rwhp. Might want to rethink the outlaw trans, I've heard a lot of bad stuff about that shop.
Old Sep 27, 2008 | 10:22 AM
fletchls1's Avatar
if your only wanting "atleast" 700whp then a 76 will be able to get the job done with some nice spool for the street even.
Old Sep 27, 2008 | 11:34 AM
Mr.MartyStone's Avatar
Ditto, give Rossler or Coan a call.
Old Sep 27, 2008 | 02:42 PM
Honestly I was hoping for "atleast" 700rwhp. Everything else would just be for bragging rights. Besides who needs 700 when you can have 1000. Well if anyone else has heard bad things about outlaw transmissions please let me know. I don't want to drop $3500 on a bad deal. Does anyone else know of some shops that build a strong 4L80E capable of handling the power I'm planning on making?
Old Sep 27, 2008 | 03:00 PM
calongo_SS's Avatar
Outlaw Review
Go with a FLT trans with out a doubt.
Old Sep 27, 2008 | 03:53 PM
02SSLE's Avatar
RPM is really good also.
Old Sep 27, 2008 | 03:54 PM
02SSLE's Avatar
There are a few guys on here making close to 1000rwh with the 80. If I am not mistaking MightyMouse is running one on his setup still.
