Where To Buy Parts For 6 Rib To 8 Rib Conversion?
I need to convert my 6 rib D1SC to an 8 rib set up. I need to know were to get the parts and I dont want to have to buy a new balancer. I would like to put the crank pulley on the outside of my stock balancer like the 6 rib.
Thanks
Thanks
Holy crap do a fking search Douche bag. J/K
http://www.atiperformanceproducts.co...harger.kit.htm
There you go Michael
Now as for the OP's original point, you stated you want an 8 rib crank pulley that can attach to the stock balancer. There is only one company I am aware of with an option like this, SDCE.
When I spoke with them about it they would only sell it to me if I also bought their entire bracket kit (Tensioned setup). Also they told me they do not recommend this style crank pulley for anything more than mild boosted setups.
I wish you luck in your search.
I'm sure EPP can correct me if I'm wrong about included items in their kit, but I was quoted half that price direct from Procharger. Getting the 8 rib crank and blower pulleys, standoffs, misc bolts and fasteners which are longer/different than the 6 rib kit, spacers for the blower pulley, and a belt, only thing not included was the idler on the bracket. In the end you still have to buy the ATI Balancer.
My price includes a new bracket assembly which is why it is more expensive.
SDCE is correct in saying they don't recommend the factory balancer for higher boost applications. The reason is the stock balancer is not designed for the crank pulley to bolt to it, other than with the center crank bolt. Bob
And I take your advice seriously for the stock balancer not being designed for it. Which is why I chose to go with a new balancer after researching it.
