Term ""Pushing Water"" Explain
Explain. I know some other newbie FI people prob dont know the answer.
Draining your coolant can every pass is a good way to check and see if your pushing water.
A way to tame it down a bit, is to o-ring the head and or block. However, being only a 4 bolt design, you will have issues with it regardless.
It can puke out some water due to pressure.
A lot of ideas of what helps on here. Me, I like the thicker deck heads & a good tune.
You can run less timing and that will help, but eventuly it will start to push water. Some say o-ringing the block and head will help, but eventuly it will push as well.
Hunter is correct, the 4 bolt will only hold so much. Kind of like over inflating a tire, eventually it will pop.
For everybody under 1000ish, this should not be something to loose sleep about, you will most likely never encounter it. The blower guys might, but that is only due to the engine being stressed alot more then a turbo ofthe same HP, see parasitic load.
When you lift a head and the combustion gases pressurize the cooling system, what exactly is happening?
Are the head bolts/studs stretching to a point where the head physically lifts a miniscule amount because there isn't enough clamping force. Thus, allowing the combustion to blow past the head gasket?
or
Is it the deck surface of the head flexing from the excessive cylinder pressure, allowing the combustion to blow past the head gasket?
You hear so much about running aftermarket heads with a thicker deck, I'm really not sure what exactly the right answer is.
