Fuel system for 1000 hp setup, 98 tank with sump?
Wondering what is required, and if a $3000 system is required.
Has anyone had luck using a 98 steel tank with a sump welded in..
LS1TECH Sponsor
I can easily build you a kit to support 1000hp, without sumping the tank.
My twin intank systems will fill your needs, while being quiet & very streetable... and for approximately half of the $3k you mentioned, I can build you a system with everything you need, from the pumps up to & including the rails.
Feel free to call if you need more info.... I also have evening/weekend hours.
Everyone that has tried to sump a stock tank says it cost just about as much as one of our race tanks by the time they got it to seal and coated to prevent rust. Me and Lonnie have great kits that can suit your needs.
Nate
Nate
