Which injectors to use? 30lb/36lb/42lbs w/ Comp 287 XER cam?
I will be putting a cam over the winter and wanted to make sure I get the right fuel injectors setup with my cam.
Stock LS6-CAI/Headers
Cam: comp cam 287 XE-R:Adv. Dur. 287 Int./289 Exh.; Valve Lift .605 Int./.609 Exh.; Lobe Angle 112 deg.;
Am I missing anything else?
That cam will be awesome with 11-1+ compression and a stage 2 or 3 cnc factory head or 215-225 aftermarket head, and a FAST 90-90. Your 39# inj should work fine. Hopefully, you can get some dyno results in the spring. Good Luck.
PS, Comp Cams has the new Ultra Pro Magnum rocker arms and lifters I saw on LSXTV at SEMA. Check it out.
Are you talking about the 03/04 Cobra 39# injectors?
From what I've read the spray pattern is not the best for our motors...since on the Cobra they are 4 valve heads...
I did a search and read about the different spray patterns.
I also found this from http://www.fiveomotorsport.com/Injec...ODS.asp#cng150
Ford rates this injector at 39lbs/hr.
User Note: The Bosch/Ford 0280156127 is a highly efficient fuel injector that incorporates a wide-cone fuel delivery. Use in engines with single- and multi-intake valves.
