Gauge/ Tank/ Sender/ 98 vs 00 Question
LS1Tech Co-Founder
Can I...
Run a 2000 sending unit in a 1998 steel tank, even if I am not using an intank fuel pump?
(And I don't want to talk about aftermarket tanks, I don't need a $700 tank for this car).
LS1Tech Co-Founder
Need to run fuel line for low pressure fuel system, need steel tank to tig weld in a bung.
I've heard I could run a high pressure intank setup and then drop the fuel pressure with a regulator, then I could use this other tank I picked up which is plastic. But can I take a high pressure pump and drop the fuel pressure to 7.5 psi?
LS1Tech Co-Founder
Hey Lonnie, thanks a million for talking last night. You answered a bunch of questions that nobody seemed to know the answer to!
Based on our call, I'm looking for the tank, and once I secure that I'll get a hold of you to piece it all together.
