Going lean under acceleration
I have checked for vacuum leaks and found none (reads 20 inches at idle), run heavy duty fuel system cleaners (BG 44k), replaced the fuel filter, replaced the pcv valve, and cleaned the MAF.
Yesterday I reset the computer after a short burst where the code was set and decided to gradually accelerate going up to 6k rpm in first and second. Under more gradual acceleration to the same high rpm no codes are set.
What would be different about the demands of the engine stabbing the throttle versus gradual accel? I am thinking the fuel pump is running out of steam up top. Pressure regulator issue?
Running at idle, up to temperature 59psi.
Normal driving, smooth acceleration 59psi.
Wide open throttle 55psi.
Shut off after running 50psi.
Would these figures point to a weak fuel pump for an LS1 camaro?
If anyone else is having a similar problem you may also be experiencing a stumble around 2500rpm, I thought they were unrelated issues.
https://ls1tech.com/forums/new-ls1-o...-question.html
