limits of #42 green tops svo?
Whats the horse power limits of these injectors using the stock fuel rails on a ls1, given its a boosted motor, stock fp is at 58psi, and has a 1:1 rising rate regulator? I am hoping these will support 650whp given proper fuel pump. can anyone give me a good idea? I know they are 42pound injectors but thats on fords, we use more fuel pressure so arnt they more like 48 pounders? excuse my ignorance.
Depends on your setup. On my Procharged, stock motored '02 Z28 the 42# green tops hit 100% duty cycle at 5300 RPM when I pullied up for 10 psi of boost. It only put down 542 RWHP due to running out of injector. I have installed Siemens Deka 60# injectors and am upgrading the fuel pump to match. Going back to the dyno soon, but am sure the Siemens injectors have given me the room I needed.
http://www.csgnetwork.com/fiflowcalc.html
My experience the 42's won't get you beyond 500 but as stated each system seems different
