Fast 102 and racetronic inj.?
i have just received my fast102 intake, verry nice, looks like my racetronic inj 42lb #135-621031 are not going to fit on intake, the body of inj seems to big to clear the intake, i have a 402 ls2 base stroker in my 2002 camaro with the ls6 intake and rails, i have ordered the billet rail and hoses and 102 bigmouth t/b, doses this mean i am going to have to buy new injectors, and if so what brand is going to fit, all this is costing a fortune.
http://www.corvetteinjectors.com/sho....php?groupid=9
I have a fast 92mm intake and a stock ls1 fuel rail ,I plan on making 440+ rwhp.I looked at your ls142 injector ,says it is rated for 36# is this correct.I think I need a 42# injector.
Turd Gen Guy
are they ls1 length, ls2 length or ls3 length injectors? i have ls3 injectors and the fast injector spacers on mine.the stock ls2 height injectors is what u need. ls1's are a bit longer than the ls2's. and you may need the orange lower o-rings. they are a bit thicker than the ls1 style. correct me if im wrong.
My injectors were fine, i found a bag of larger o rings in the box that the intake came in from fast, they went on the inj. and in the intake fine. service,price and delivery was fast for the injectors, thanks ,assembled all togheter tonight, looks great, now i will be waiting for the hose
got my hose, had to grind rear of intake to clear oil pressure switch and top of water pump, used modeling clay to check clearence, hard to see back there, make sure you's check.
